According to this the 997 turbo will use the 3.8 liter 997 motor.
If this report is true the 997 turbo will use the 3.8 liter 997 motor. That kinda sucks because it will not be able to handle the type of mods the 996 turbo motor does.
http://www.autocarmagazine.com/News_...p?NA_ID=214834
Anyone else hear anything?
"Meanwhile, the success of the 911 Turbo Cabriolet, re-introduced late last year after a long hiatus, appears to have cemented its place in the Porsche line-up. The new model, revealed (right) with a hard-top in place, is rumoured to run a twin-turbocharged 3.8-litre flat-six engine with 480bhp – up 60bhp on today’s model. However, Porsche is also working on an S version with a 525bhp version of the same engine."
So I guess that I will stay with my 996TT since it has more HP than the new S that is coming out.
998TT hurry up!!!
998TT hurry up!!!
Re: According to this the 997 turbo will use the 3.8 liter 997 motor.
Low compression 3.8...
Buddy,
According to this thread the 997 GT3 and turbo/GT2 models will still be based on the GT1 motor.
https://www.6speedonline.com/forums/...threadid=26034
To make a 3.6 L into a 3.8 L all they have to do is use a 102 mm piston and liner in place of a 100 mm piston and liner.
Originally posted by rockitman
Yes, I am starting to hear that the GT1 based motor will be in the 997GT3 too, in lieu of the much rumored 3.8 wet sump motor...
The GT1 uses a three index oil pump ............. would someone mind explaining further????
Originally posted by cjv
GT1 based motor? Is there something I am missing?
[QUOTE]Originally posted by rockitman
well not sure what you mean by 3 index oil pump...it will be like the current motor with dry sump, lightened pistons and valves, titantium rods, GT1 crank and the 964 now made in spain block. Just like the current 996 GT3 version w/ perhaps different engine mapping and a little more displacement ? I think it will still be 3.6. After all, the RGT puts out 400hp at the crank with the 3.6 motor and different ecu map, ect. [/QUOTE
Rocket,
This is not a flame. The GT1 motor really isn't that special other than the oil pump. In racing trim it produced 600 hp. Yes, it had titanium rods, pistons were not that special and current GT3 crank is superior.
Yes, eight years ago it was special.
Rocket,
Rocket,
Rocket,
I BELIEVE the GT1 motor was developed from the stock (at that time) motor, at least the case. It had the dry sump. I think it was even stamped with a 964 casting number.
The Turbo motors are built on thier own line at the factory.
still pretty special in current Porche Cup competition. The 997 GT3 Cup's basically use the same motor...
GT1 Pump
