GIAC flashloader switcher detectable?
Old May 7, 2005 | 08:31 PM
ypshan's Avatar
ypshan is infamous around these parts
If one flashes the ECU program back to stock before taking the car to the dealership using the flashloader switcher from GIAC, would the dealer be able to detect that the car has been reprogrammed?
Thanks.
Old May 7, 2005 | 08:32 PM
20C4S's Avatar
i believe not.
Old May 7, 2005 | 08:45 PM
sharkster's Avatar
nope... if you're in stock mode your safe:P
Old May 7, 2005 | 08:56 PM
aj996tt's Avatar
aj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond repute
Do y'all raise the redline? If so, would max rpm be a clue?
Old May 7, 2005 | 09:30 PM
ypshan's Avatar
Redline stays the same.
What if the dealer flashes a new version of the factory program onto the ECU?
Would one have to go to the GIAC dealer to save the new version of the factory program so to avoid flashing the older version back next time?
I am not sure where the different programs (e.g. stock, pump gas, racing gas) are stored. Are they stored in the handheld flashloader switcher? Or are they all in the ECU and the switcher just let the owner pick one of the programs that's already there?
Old May 7, 2005 | 10:58 PM
PorschePhd's Avatar
The programs are in the ECU, not the hand loader. The hand loader should be considered like a mini computer that access the info on the main frame..the ECU.
The ECU is not detectable by the PST2 or 3.
Old May 8, 2005 | 09:05 PM
ypshan's Avatar
Thanks PorschePhd.
In that case, if the dealership service department flashes a new version of the factory program into the ECU, would it wipe out the GIAC programs?
Did they ever do it before?
White991TT
Mar 8, 2016 06:01 AM
sdg1871
Nov 22, 2015 07:27 PM
Oct 2, 2015 02:23 PM
sdg1871
Sep 29, 2015 09:30 AM
