Question for 996 Turbo owners: Any of you show 1.5bar oil pressure...
Old Dec 6, 2011 | 09:06 AM
bng4god's Avatar
bng4god has a spectacular aura aboutbng4god has a spectacular aura about
when the engine is warmed up and at idle? If so, did your low oil pressure indicator warning light come on? I am trying to troubleshoot an issue of mine and determine if the warning light should come on at 1.5 bar or if there is some faulty sensor. Thanks for the help guys!
Brent
Old Dec 6, 2011 | 10:56 AM
NineElevenLover's Avatar
NineElevenLover is just really niceNineElevenLover is just really niceNineElevenLover is just really niceNineElevenLover is just really niceNineElevenLover is just really nice
Brent
No need to worry. This is most likely just a failed sensor/sender-unit. Have you gotten the indicator failure warning on your dash?
Old Dec 6, 2011 | 11:08 AM
bng4god's Avatar
Yes, it would pop on and off and seems to trigger at 1.5 bar which is strange since I don't think that's really low pressure. It's never dipped below 1.5 bar when fully warmed up at idle. I think it's time to replace the sender unit. The question is now, while I am at it, should I replace the diverter valves so to get ready for an ECU tune...
Old Dec 6, 2011 | 11:29 AM
johnspeed's Avatar
HI,Mine will also drop down to 1.5 bars when fully warmed up at idle,,,no problems..Good Luck
Old Dec 6, 2011 | 11:36 AM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Up to you on the diverter valves, I suppose it would provide better access to the sending unit from the drivers side of the engine. I followed the shop manual when I replaced the sending unit, removed Y pipe, and throttle body. It's in an odd location, and can be a bit difficult getting leverage on it, I think I used a crows foot on a small flex head ratchet.
Cleaned the TB while I had it out also ...
Good luck.
BlackMarketRacing
Dec 8, 2015 01:49 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
Aug 19, 2015 06:55 PM
