What Size Trolley Jack?
Old Dec 19, 2011 | 11:39 AM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
I currently have a 2 ton trolley jack
Minimum height is 130mm
Maximum height is 345mm
My axle stands have a 6 ton rating and a ratchet action
Their minimum height is 400mm
Maximum height is 615mm
The trolley jack I have at present doesn't go low enough to fit under the car, and doesn't lift high enough to allow me to get my axle stands underneath it either
I've got the scissor jack that came with the car, so I could use that to raise the car slightly and then get my trolley jack under one of the other jacking points if needed
What would be the best way to get my car up onto the axle stands?
Can I use the jack(s) I already have, or should I buy a new one?
Old Dec 19, 2011 | 11:57 AM
ant_8u's Avatar
Just seen these on YouTube
Old Dec 19, 2011 | 01:47 PM
ant_8u's Avatar
Currently reading about Arcan Jacks
Anybody got any experience of them?
Not heard of them myself, but I'm guessing they're American?
Old Dec 19, 2011 | 04:46 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
For the money Harbor Freight has a standard size jack with a very low profile (2 3/4"). It's the only jack I can get under my car which is lowered just above GT2 ride height. I even have room to slip my jack pad guide plates between the jack saddle and the jacking points. I have some trolley jacks but they are more trouble to use and as you've pointed out you don't get much lift.
Old Dec 21, 2011 | 11:40 PM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
I have 2 lengths of 2 x 12 I've tapered on one end that I drive on. This gives me enough clearance on my lowered Turbo to jack & place stands under it.
Old Dec 23, 2011 | 07:01 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
Low rise jack is the only way to go. Makes life much easier and my car is lowered.
That YouTube stands we're pretty neat. Must use a toothed system like most jack stands as he didn't remove a pin until it was coming down.
Need to make the rear trays wider to accommodate our larger rear tires.
BlackMarketRacing
Dec 8, 2015 01:49 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
JMon
Aug 21, 2015 08:20 AM
ModBargains
Aug 20, 2015 12:28 PM
