Fluid leak while trailering
Old Dec 20, 2011 | 02:39 PM
bb996tt's Avatar
bb996tt is infamous around these parts
I noticed a small puddle of clean amber fluid that leaked out after trailering my 2001 996tt. The fluid dripped out just in front of and along side of the left rear wheel. The car was in neutral with the parking brake set while being trailered. I used the Rennline tie downs and the ratchet handles did not poke any holes in the oil sumps. I believe the fluid is Pentosin from the power steering/ clutch but I'm not sure why it would leak. The car was not leaking any fluids prior to the 1,300 miles trailer ride. Has anyone seen something similar?
Old Dec 20, 2011 | 05:14 PM
jpflip's Avatar
Pentosin leak in front , it is a possibility your clutch reservoir is overfilled that means a faulty slave actuator.... Fluid migration from the steering reservoir towards the clutch reservoir.
Old Dec 20, 2011 | 05:27 PM
joe731's Avatar
joe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to behold
fluid
Is it possible that the fluid is antifreeze? The stock antifreeze in our cars is rose colored, not the neon yellow/green of American antifreezes and with the hoses running to the front radiators, and the plastic plates under the car, if you have a small leak it could come out anywhere. Those plates come off pretty easilly if you have torx drivers and some room to work.
Old Dec 20, 2011 | 05:29 PM
joe731's Avatar
fluid
BTW, the pentosin is flammable while the antifreeze is not.
Old Dec 20, 2011 | 06:46 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
I think he's saying just in front of and around the rear left side tire. If I am understanding this correctly I'd check the coolant overflow tank for possible cracks, or if possible it was put at a high angle when loading it on to the trailer and the coolant tank leaked out of safety overfill hose as its located on that side as well.
Old Dec 20, 2011 | 07:20 PM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Amber is coolant.
Green is pentosin.
Old Dec 21, 2011 | 09:01 AM
bb996tt's Avatar
I think it was coolant overflow. The strange thing is I haven't had any service for 6 months + and I have been driving the car occasionally prior to trailering, so the coolant level should have stabilized.
What changed during the trip down to Phoenix was the altitude. Traveling west to Flagstaff, AZ before turning south to Phoenix, the altitude gets up to 5,000 to 6,000 feet, I think that is what caused the coolant to overflow.
Thanks for the input!
E55 Bulldog K2
Dec 15, 2015 08:38 PM
cockneymike
Oct 22, 2015 06:00 PM
laz74
Oct 2, 2015 06:08 AM
MrMiggy
Sep 14, 2015 02:18 PM
sparks
Sep 8, 2015 03:03 PM
