Power Steering Leak
Old Sep 9, 2015 | 10:04 AM
MrMiggy's Avatar
MrMiggy is a jewel in the roughMrMiggy is a jewel in the roughMrMiggy is a jewel in the rough
Angry Power Steering Leak
I noticed an unusual whine coming from the driver's side of the engine compartment the other day. Sounded like the power steering pump was struggling. I checked the fluid and sure enough -- it was below the "low" point on the dipstick.
I refilled with Pentosin CHF 202 and everything was fine -- for about 24 hours. My wife took the car out the next day and reported that the noise was back. Sure enough, the fluid was below the "low" point again. I can see green power steering fluid on the pan underneath the engine by the passenger side front wheel. We've got a leak of some sort!
We had a thorough PPI when we purchased the car and the fluids checked out. Certainly no leaks were found. Just bad luck I guess.
I left the car with my mechanic this morning. I will report back once we know the diagnosis.
Old Sep 9, 2015 | 11:52 AM
Goonie's Avatar
Goonie is infamous around these parts
No results in here but you're not alone... http://rennlist.com/forums/panamera/...ring-leak.html
Old Sep 9, 2015 | 02:27 PM
MrMiggy's Avatar
I found that thread too. Thanks for posting it. Verdict is in: the rack is leaking on both sides. Both boots were full of fluid. A new rack is $2,500 from Porsche.
Old Sep 9, 2015 | 02:45 PM
Goonie's Avatar
You're gonna think I'm cheap but a reconditioned rack is cheaper
http://www.partsgeek.com/x2svx9w-por...+Steering+Rack
And labor should be around $700 from what I can see.
Old Sep 9, 2015 | 02:50 PM
MrMiggy's Avatar
I found one at Pelican Parts but for some reason it won't work with my car. Lack of PDCC or something like that.
Old Sep 11, 2015 | 07:52 PM
Peach PTT's Avatar
Peach PTT is infamous around these parts
Would this be covered under CPO warranty?
Old Sep 11, 2015 | 07:59 PM
Goonie's Avatar
Yes it would. Everything except normal wear and tear items like brakes and tires.
Old Sep 11, 2015 | 08:05 PM
NiceCar's Avatar
NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !
I was told things like rattles, that are covered under the original warranty, aren't covered by CPO.
Old Sep 11, 2015 | 09:33 PM
Goonie's Avatar
Depends what's rattling I guess. Steering rack will be covered under warranty.
Old Sep 12, 2015 | 03:15 AM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
Very sorry to hear these. My 2011 ptt steering does a squeak sound when turning on the car and the steering moves to go in its saved position and the cayenne steering squeks since 3 years now !
Old Sep 12, 2015 | 07:32 PM
MrMiggy's Avatar
This ain't a rattle. The steering rack was gushing fluid out of both ends.
Car should be ready Monday. I had my mechanic do a full brake job while he was waiting on parts. Hopefully like new!
Old Sep 12, 2015 | 07:55 PM
NiceCar's Avatar
Oh, I know. What I meant was that there appears to be a difference between the original factory warranty and the CPO one in terms of the level of failure/defect/wear they consider covered under the warranty.
Old Sep 13, 2015 | 10:29 PM
Goonie's Avatar
did you go with OEM brake parts?
Old Sep 14, 2015 | 02:18 PM
MrMiggy's Avatar
Yeah, I didn't really have the time to research alternatives. OEM works fine.
Michael_s
Sep 11, 2015 08:03 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
Zero911
Aug 24, 2015 06:51 PM
JMon
Aug 21, 2015 08:20 AM
