Tapping transmission case for GT2 slave conversion
Old Mar 23, 2023 | 03:07 PM
  #151
John@SpeedTech's Avatar
The fork on the non assisted set-up is a mirror reverse of OEM power assisted version fork found on the turbo. The pressure point is on the other side, which is why the non assist slave is drilled and tapped opposite the OEM. That large hole is for the OEM slave set-up. You need to get a cap/plug for that hole, as it will no longer be used and should be sealed.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Mar 23, 2023 | 06:34 PM
  #152
sjbdeebo2's Avatar
sjbdeebo2 is infamous around these parts
Originally Posted by Slider
It looks like someone changed the transmission to use the GT2 slave instead of the OEM accumulator arrangement. Excellent idea to have an opening to allow you to hold the rod while getting the slave bolted in!
I drilled and tapped my trans. I was curious if I should drill the other hole as well
I bought the gt2 fork. I didn’t get the plug because I wasn’t planning on drilling out the other hole. But now I might. This is the first picture I came across with the hole there when doing the conversion
SharkyShark20
Sep 19, 2015 09:54 PM
GetALife75
New Member Introductions
Sep 3, 2015 12:22 PM
Murf4
Sep 3, 2015 10:10 AM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
