Tapping transmission case for GT2 slave conversion
Old Jan 15, 2012 | 05:17 PM
  #46
John@SpeedTech's Avatar
Ed,
How much did you end up adding to the length?
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Jan 15, 2012 | 06:37 PM
  #47
02turbo996's Avatar
02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future
Originally Posted by raineycd
It may need to be shorter to make the engagement lower? I assume you had to cut it, or did you lengthen it?
I added 1/8" to the stock GT2 length because of our assumptions with the case not being machined like the GT2 is. I'm guessing the stock rod would be just right. I want to have a rod ready so i can swap it out fast.
Old Jan 15, 2012 | 06:41 PM
  #48
02turbo996's Avatar
Originally Posted by John@SpeedTech
Ed,
John,
After reading how people add or remove from these rods, i'm going to guess that each clutch will be different. I suggest everyone start with the stock rod and then adjust after driving it for a day or two to let the clutch disc settle with the PP.
Old Jan 15, 2012 | 06:56 PM
  #49
You know, we used a Euro 993 GT2 part that someone mentioned to me has a slightly shorter rod than the newer GT2 slave that you used - I was told about 1/4" shorter. If this is true, I'll bet with the newer slave my action would not be as close to the floor and probably perfect without extending it. And I think you are probably correct about driving it first, then adjust only if required.
2022 Cayenne White
Old Jan 15, 2012 | 07:03 PM
  #50
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Nice write-up!! I'll be following this when I do the same conversion to my 997.1tt.
Old Jan 21, 2012 | 06:51 PM
  #51
02turbo996's Avatar
Positive update!!..... I pulled the slave out (takes 5 minutes now) and shortened the shaft and WOW soo much better.
Here's the deal, all the people that have the high engagement point like i had need to do this because it reduces the pedal effort for some reason. It was a little stiff with the high engagement point but now it's in the sweet spot and is not bad at all.
I was way up on the pedal, about the first 8-10%; i'm down to about 65-75% now. I cut out about 1/4" of the shaft. Now it's about 1/8" shorter than the stock GT2 rod.
John, 1/4" should be the sweet spot for you from what you've told me your car engages at.
Old Jan 21, 2012 | 07:09 PM
  #52
Thanks for the advice, I appreciate it!
2022 Cayenne White
Old Jan 21, 2012 | 07:58 PM
  #53
raineycd's Avatar
How hard would it be to cut the shaft on a stock slave? Is it easy to get out and back in? Mine engages very high right now...
Old Jan 21, 2012 | 08:32 PM
  #54
Tim941NYC's Avatar
Its not hard, Make a sleeve to slide it in and then weld the shaft ends to the sleeve. Its a real PITA to get the stock slave out. If you are going to go that far just do the gt2 slave. It will only be another 2-3 hours work. with the flush and bleed.
Old Jan 22, 2012 | 05:52 AM
  #55
02turbo996's Avatar
Also, if you can find a tube to fit the rod you can use a piece of angle iron and lay the two pieces of rod in the valley. Use clamps to hold it down and then spot weld one side, turn and then finish welding all around. That's how i did mine.
Old Jan 22, 2012 | 07:31 AM
  #56
Dr. Jekyll's Avatar
Dr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of light
Anyone know the stock GT2 slave rod length and the stock turbo slave rod length?
I'm currently using stock turbo rod in my GT2 slave setup and with my Spec clutch the engagement point is pretty high. If I can, I'd like to bring the engagement point down a little bit but I'm not sure how much material to remove from the stock rod. TIA!
Old Jan 22, 2012 | 01:06 PM
  #57
G50CARERRA's Avatar
G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !
Ed if you have that bad boy up and running, I would love to get a ride. Will pay for gas and beer
Old Jan 22, 2012 | 03:19 PM
  #58
VAGscum's Avatar
Where in Fl. are you guys? Would you be interested in a GTG for beers and car talk?
Old Jan 22, 2012 | 03:51 PM
  #59
02turbo996's Avatar
Oh she's running! I'm going to Daytona next weekend for the race with family but maybe the weekend after that? I have that Friday off.
Old Jan 22, 2012 | 03:52 PM
  #60
02turbo996's Avatar
Melbourne area for me.
