strut mount knocking up front... upgrade or replace?
Old Apr 23, 2012 | 07:30 AM
VAGscum's Avatar
I just did a suspension swap an had the same rattling and clunks up front. The front shock mount bearings were completely toast. Reaplce them and while you are in there inspect the rubber when the mount is off. Trust me, if your sway links are healthy the bearings are most likely toast.
Old Apr 23, 2012 | 10:23 PM
VAGscum's Avatar
I would also like to add that the front strut bearings I replaced are updated design. The ones that came on our car come apart and let dirt in. The new ones are one sealed piece. FYI. So the old design is inherently flawed IMHO.
Old Apr 24, 2012 | 04:52 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
I also had / still have knocking even after the pss10s upgrade. I replaced the whole front shock mount including rubber, to no avail. I checked stabilisers and have no play anywhere. I don't have it over the winter and cold days. Once the weather warms up I have this rattle. I haven't managed to pinpoint the location yet. Bloody annoying.
Old Apr 24, 2012 | 06:11 AM
VAGscum's Avatar
Possibly a control arm worn?
Old Apr 24, 2012 | 07:25 AM
Terminator's Avatar
No play in ball joints. What is weird nothing in cold weather. And it is not getting worse. Always the same. Goes in winter. Back in the spring.
Old Apr 24, 2012 | 08:20 AM
powderjay's Avatar
powderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to behold
Just did the pss10 as well and noticed some low speed clunking up front
Have not fully investegated yet but will add my 2 cents when I find the culpret.
Old Apr 24, 2012 | 11:56 AM
Tim941NYC's Avatar
guys double check you end links. tighten them down really good. there is play in the hole that the link bolts through to in the bar so if the clamp up of the bolt is not enough (cant tell be winging it by hand) it will move a bit the stop when it bottoms out on the other side of the hole. Also will make noise too.
Old Apr 28, 2012 | 03:43 PM
powderjay's Avatar
Solved my noise issue. Several of the supplied bolts from the pss10 get became loose after a little driving. I had to replace the with nylock bolts and so far she sounds great again.
Old Apr 28, 2012 | 04:18 PM
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
How do you like your PSS-10 so far, compared to stock? Ride height, damper settings, handling, etc.
Old Apr 29, 2012 | 06:21 AM
powderjay's Avatar
Smile
Haven't had a lot of time or miles with them yet. Car has had a bunch of stuff done to it and Ive been working out the kinks. This knocking being one of them. Have not made any adjustments, but overall too early to give a proper rating.
Jul 29, 2019 11:13 AM
vr6tee
Aug 29, 2015 03:52 AM
The Oss
Aug 24, 2015 08:19 PM
pwdrhound
Aug 23, 2015 07:36 PM
su_maverick
Aug 21, 2015 07:14 PM
