greedy boost control: any issues???
Old Jan 3, 2012 | 06:25 PM
mod mike's Avatar
mod mike has a spectacular aura aboutmod mike has a spectacular aura aboutmod mike has a spectacular aura about
any one have problems with the controller boosting beyond the set high limit? thinking of getting one, here's whey.. my car has two files, pump and 100 octane. would like to lower the boost for canyon runs, but raise the boost to max, 1.3 on 100 octane when on race fuel around the street... the controller has always made me nerves, is there any reason to be? i know not to set it beyond the set limit of the tune.... thanks guys!
Old Jan 3, 2012 | 08:37 PM
The rest of the world runs EBC in just about every tuned turbo car there is...
If you know what your doing it can be a really cool tool to use. I never had a single client dislike it once he understands it.
However, your car will throw a code for the missing N75 valve unless your tuner turns off the diagnostics for it in the mapping.
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 3, 2012 | 10:05 PM
Tim941NYC's Avatar
Mark, The last post about a boost controller you stated you can not run one with out being tuned to use one. I stated that if you are not looking to add more boost then tuned for there is no problem because the ecu will not see inputs that it does not have files for already. The OP of that post was looking to do the same thing. True or false? I know the answer. Also the fix for the N75 is to leave it plugged in and not connect it to any tubing.. No CEL.
OP, when turning down the boost on a race file, the ecu will try to run higher timing values but will pull the timing from inputs for knock sensors. When you change the fuel the ecu will adapt to the higher octane after a while or you can clear the ecu with a scan tool and force the ecu to adapt to the fuel in real time. hope this helps.
Old Jan 3, 2012 | 10:21 PM
Tim941NYC's Avatar
https://www.6speedonline.com/forums/...996-turbo.html
Post #9 to be exact. Sorry for hijacking your thread but the real answers should be out there for anyone to research as I am sure the OP did and seen this thread so asked this question in a different form.
Old Jan 3, 2012 | 10:38 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
why you do not get HKS EVC6 , much easire and hold the bost very well
best,yousef
He can also just run a manual boost controller inline with the n75. Less work to install cheap and works. I never ran the ebc with the n75 connected. There are 3 map values that turn off the n75.
EDIT: you have Proto tune.. email Todd and ask for the tune that runs the EBC... simple... either express the ecu or use Dura... most tunes have 3 free upgrades... Im not sure what you paid for..
done deal..
markski
Old Jan 4, 2012 | 08:22 AM
Tim941NYC's Avatar
Turn down the music and stop dancing around the question.
Old Jan 4, 2012 | 04:40 PM
mod mike's Avatar
thanks guys... mark: i looked at your site and do you not offer this? is EBC the name brand??? what do you use Tim??? the wethers so nice i came home just to take the P to the beach.. 86 degrees
Old Jan 4, 2012 | 05:04 PM
Greddy profec B spec II thats what you need..
9.66
click to view
Old Jan 4, 2012 | 07:56 PM
Tim941NYC's Avatar
I run a HKS EVC. I do not know what number they are up to now. my is 4-5 years old. Easy to adjust and pretty much bullet proof.
Old Jan 5, 2012 | 05:49 AM
ttboost's Avatar
HKS EVC was the best I ever used, but never used one on my 996tt. Keep in mind if you run a boost controller on your 996tt, you are limiting how much your ECU can protect you (It cannot reduce the boost, if it overboosts, etc..). If you get a Electronic Boost Controller, learn it, live, love it....
Old Jan 5, 2012 | 07:24 AM
raineycd's Avatar
Actually there is an overboost protection setting on the Greddy that allows the controller to turn the boost down if an overboost happens. Similar to what the ECU would do if an overboost happens.
And yes, you must know what you are doing and keep an eye on things with an EBC.
Old Jan 5, 2012 | 08:00 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Chad, I think you misunderstood TTboost. He meant that if you add an ebc, the ECU will no longer save your but from over boost.
Old Jan 5, 2012 | 08:07 AM
raineycd's Avatar
No I understand what he was saying I just wanted to add that there is still a safety with the EBC. It is not Russian roulette, there are still safety controls in place.
Old Jan 5, 2012 | 11:39 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
Exactly. And if the EBC fails, you ride your wastegates. I have a .9 bar spring in my Tial's so for the track, wet and cold I just turn mine off.
Tom
