Need to lift my car, need your help!
Old Jan 5, 2012 | 12:07 PM
mikble911's Avatar
mikble911 is infamous around these partsmikble911 is infamous around these parts
I need to put my 02 996TT on jack stands but I want to be sure I do it right. I've read too many posts where people have bent suspension etc. and I don't want to add my name to that list.
I have the front end on stands already and believe I need to lift the rear of the car from below the rear differential but I'm not exactly sure where to place my jack. Can someone point out on a photo exactly where I need to place the jack so I don't mess it up?
Thanks in advance for your help!
Old Jan 5, 2012 | 12:29 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
Look along your side skirts, you will find two little triangles. One by the front of the door one by the back of the door. Follow that arrow under the car and you will find a the factory jack point. (looks like a circle cut into the plastic with a slot to accept the factory jack).
If your using a aftermarket jack make sure your jack plate is right in line with the circle cut out so you don't crack the plastic. It's easy you'll find it.
Old Jan 5, 2012 | 01:29 PM
mikble911's Avatar
Yes, that's where I'll put my jack stands, but I've got to get the car up first and that circle is not large enough for both the jack and a jack stand. I think I need to jack the rear up from below the differential so I can then place my rear jack stands at the factory jack point locations.
Old Jan 5, 2012 | 06:42 PM
mikble911's Avatar
Here's a picture, (lifted from Betcha's thread, thanks!). Could someone just photoshop an arrow or something!
Thanks guys!
Old Jan 5, 2012 | 07:17 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
https://www.6speedonline.com/forums/...under-car.html
This should help, follow the links, the Renntech link is very good ..
Old Jan 5, 2012 | 07:31 PM
mikble911's Avatar
Thanks, this is exactly what I was lookiing for! Much appreciated!!
PorscheEnthusiast
Nov 13, 2015 02:23 PM
r_matt_6
Oct 8, 2015 06:07 PM
gulf gt
Aug 27, 2015 10:27 AM
WheelB
American Muscle
Aug 24, 2015 08:42 AM
silver86
Cayenne 958
Aug 21, 2015 03:08 PM
