More pressure testing assistance, making progress
Old Jan 13, 2012 | 08:51 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Can anyone confirm whether or not part #9 in the diagram below is a check valve and should PREVENT air from escaping from the end of part #6 (see red line / arrows), while under pressure ? Sorry for the lame markup, paint on Windows XP isn't all that flexible.
I had the hose disconnected as I just replaced my F-hose and bypass valves, and thought I would continuing pressure testing (from the turbos), before reconnecting the hose and clip. If part #9 is supposed to act as a check valve blocking air from entering hose part #6 from the intake plenum behind the throttle bottle, then it looks like I may need to replace this also.
Much appreciated.
Old Jan 13, 2012 | 09:39 PM
Tim941NYC's Avatar
I think that it should not let air out it to line #6 I will check in the am. That is for the brake booster so that should only see vacuum. When the TB is closed boost/ vacuum enters #12 then over the venturi and into the plenum threw #11 to pull a vacuum on line #6 I do no use that piece any longer and have not noticed any side effects. Not sure its a good idea though so not recommending anyone to remove it.
Old Jan 13, 2012 | 09:48 PM
JSBear's Avatar
I had a feeling, looks like a check valve is built into
that part. Since it's connected to the intake plenum, I figured it shouldn't bleed air to part #6 under pressure. Glad I checked it while it was disconnected, otherwise I may not have caught it.
Let me know what you find, as before, thank you for your assistance
Old Jan 14, 2012 | 11:24 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
Man I HATE that little piece of plastic. I mean really hate it.
Mine failed where the little venturi mates to the top piece. It took me forever to find it, as I could not see the bubbles from my soap spray.
darn thing is expansive too .. . . .
Tom
Old Jan 14, 2012 | 12:21 PM
JSBear's Avatar
Mine does not appear to be leaking externally
Appears that there is a check valves built into the end that attaches to hose part #6. I have air escaping here when I pressure test.
Tom
Old Jan 14, 2012 | 01:06 PM
Tom
I found them leak around the outer rim and yes they are expensive...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 15, 2012 | 01:02 PM
Tim941NYC's Avatar
I do not use that piece as I stated, I found it (lucky) and it in fact is a check valve too! It will not let air back feed into hose #6,
Old Jan 15, 2012 | 04:07 PM
JSBear's Avatar
Thanks for confirming, ordered the part last night from
Pelican.
Are there any other check valves I should be checking that are prone to failure ?
Old Jan 16, 2012 | 08:10 AM
Tim941NYC's Avatar
Originally Posted by JSBear
Pelican.
How about the one for the oil sump? Off the top of the sump tank a line goes to the plenum.
Old Jan 16, 2012 | 09:34 AM
tvurt's Avatar
That one failed on me too . . .passenger side just off of the top of the T-plenum.
Just to add to the fun of pressure testing, I actually had a crack that was at the base of one of the nipples on the top of the T-plenum. I epoxied it . . and it only held for a few months. I replaced the unit with cayenne TB and a new T-plenum.
Jul 29, 2019 11:13 AM
Apex Chase
Mar 28, 2016 02:00 PM
The Oss
Aug 24, 2015 08:19 PM
Gewgaw
Aug 19, 2015 11:52 PM
