Instrument surround question
Old May 14, 2005 | 07:23 AM
TestnDoc's Avatar
Senior Member
TestnDoc is infamous around these parts
How difficult is it to remove the plastic instrument surround, which surrounds the speedometer and other dials? How is it removed? I have a painted instrument surround coming from bumperplugs.com. Thanks!
Old May 14, 2005 | 08:37 AM
ColorChange's Avatar
ColorChange is infamous around these parts
I want to know also as I have a cf unit I haven't installed yet.
Old May 14, 2005 | 09:28 AM
Under PSI's Avatar
Under PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud of
I've done it and it's pretty simple. There are two or three screws that you have to remove, (one is behind the hazard surround) and the whole top section of the dash lifts out. It is then just a matter of unscrewing the old one and installing the new. I'll have to take a better look to give exact details of the job. The whole thing took me only about half an hour and I had never done it before. I likely could do it even faster now.
Old May 14, 2005 | 10:17 AM
msb2tg996's Avatar
msb2tg996 is infamous around these parts
remove the hazard switch cover, behind this there will be a screw, the next is that small round cover on your left, remove this and there will also be a screw there, when you have removed both screws, wiggle the dash upwards and the whole unit should just come up, at the bottom of the unit should be some more screws, just remove the correct ones and your done. it would take about 1/2 to do the install or less.
Old May 14, 2005 | 11:02 AM
TestnDoc's Avatar
Senior Member
What type of screws? Torx? Did you have to disconnect any power cables or the battery?? Thanks
Old May 14, 2005 | 11:56 AM
Under PSI's Avatar
You will have to disconnect all of the connectors for the dash cluster itself and for any switches. It's very easy.
Old May 14, 2005 | 12:49 PM
TestnDoc's Avatar
Senior Member
Did you disconnect the battery? Is there a power failure/security code for the PCM/radio??
twnj
Apr 29, 2016 05:18 AM
alevine
Nov 4, 2015 10:05 AM
away
Sep 4, 2015 12:30 PM
ppwchiang
Sep 1, 2015 11:22 PM
