Actual ID of factory Y-pipe at TB opening
Old Jan 22, 2012 | 10:04 AM
johnspeed's Avatar
HI Guys,,Could anyone Please tell me the exact inner diameter opening of the stock plastic Y-pipe trunk going into the Throttle body....I have heard 68 mm all the way to 75 mm???.......Thanks
Old Jan 22, 2012 | 11:24 AM
John@SpeedTech's Avatar
John,
I would have to dig mine out tomorrow and measure it, but I can tell you this...when I first went to a 75mm TB, I used it, but it was very difficult to get it to stretch over the 75mm TB and Y-Pipe ends. I had to use a lubricant and make a shoe horn like tool to get it on. It was a real PITA to do and was less than ideal from a flow standpoint, as it became narrower than the Y-Pipe opening and the TB opening when installed because the ends were stretched so much.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Jan 22, 2012 | 11:48 AM
johnspeed's Avatar
HI John,,Thanks,just would like to know now for my info ....
The throttle body's that are sold now,that I am aware of and have,,,is a 74mm by the shaft , in which their is that slight step in the body their [true measurement]......And come with a bigger hose coupling to fit easier now..
The hand ported ones that I have seen have those steps removed and it makes it a 75mm then,,,as also the opening is mouth of the TB thinned out and opened up/tapered.....I guess back in the dayTurbo Mike did them all by hand when he sold them with his plenum....
I sent the IPD plenum I recieved from TimNYC to Calico to get it coated..
Old Jan 22, 2012 | 01:07 PM
John,
Here is a picture of mine...ported, etc. - probably done by Mike back in the day...
2022 Cayenne White
Old Jan 23, 2012 | 08:44 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
TB in 71,5mm /to intake plenum 80,5mm
Old Jan 23, 2012 | 09:08 AM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Thanks for the info!
Where abouts specifically are you measuring for those numbers?
Old Jan 23, 2012 | 09:37 AM
winnigt2's Avatar
exact inner diameter opening of the stock plastic T pipe going to Throttle body 71,5mm / the opening to intake plenum 80,5mm (cross)
(have an old t style plastic)
if you need the oem y pipe diameter, i have to go again in garage smile
Old Jan 23, 2012 | 10:16 AM
johnspeed's Avatar
HI Guys,Thanks for help and info......That is the plastic y-pipe that has the legs that come from the intercooler hoses ,joins and connects to the TB.So then that opening is 71.5 mm ID??.....Sorry,I was not talking about the plastic T-Pipe.Thanks
Old Jan 23, 2012 | 11:18 AM
winnigt2's Avatar
the oem y pipe connection to TB is 68,5mm inside diameter .....that is the reason wy i prefer speed tech 75mm y pipe with a 75mm TB
Old Jan 23, 2012 | 01:40 PM
johnspeed's Avatar
Thanks,,,,that is a good reason....Even though a 74mm TB actually doesnt flow like a straight 74mm pipe due to the shaft and throttle plate restriction plus the turbulence they cause...It would be beneficial to update that Y pipe to a bigger ID....
Fabspeed Motorsport
Aug 26, 2015 11:15 AM
Fabspeed Motorsport
Aug 18, 2015 03:24 PM
