Front GT3 PCCB Rotors on Turbo (Spacer)
Old Jan 25, 2012 | 03:24 PM
NBTBRV8's Avatar
NBTBRV8 is just really niceNBTBRV8 is just really niceNBTBRV8 is just really niceNBTBRV8 is just really niceNBTBRV8 is just really nice
Guys,
Does anybody sell the spacer required to make these fit or have a diagram that I could use to get some made?
Old Jan 25, 2012 | 07:30 PM
Mpsuk's Avatar
Mpsuk is infamous around these parts
Im interested to find out too. Much easier to find gt2/3 pccb than turbo pccb
Old Jan 26, 2012 | 05:28 PM
msv's Avatar
msv
msv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to behold
The GT3 discs have too little offset for the TT. 61mm vs. 63mm for the Turbo.
A 2mm spacer between the hub face and the disc works to put Turbo discs on a GT2/3 but not the other way around.
Old Jan 26, 2012 | 06:43 PM
PAULUNM's Avatar
PAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to all
You can use a 997tt 350mm rotor, and the GT3 caliper will bolt right up.
Old Jan 27, 2012 | 01:01 AM
NBTBRV8's Avatar
Sorry I am not quite with you on this. So you have to space out a turbo disc (between the hub and back of the hat) for it to fit a GT. Thus the only way of making a GT hat fit a turbo would be to try and machine a couple of mm off it?
Old Jan 27, 2012 | 01:52 AM
NBTBRV8's Avatar
One other question. On the Gen I rotors, can you just unbolt the GT hat and fit a turbo one?
Old Jan 27, 2012 | 08:36 AM
msv's Avatar
msv
While machining 2mm off the inside face of the GT disc hat would increase the offset to 63mm, it would no longer be structurally sound.
The only way to make it work is to use the Turbo hat provided you can find one.
Old Jan 27, 2012 | 02:44 PM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
So if I got hold of a full set (4) pccbs from a GT2/3, I could use just the rotors as spares for my turbo S' pccbs by disassembling them?
Old Jan 27, 2012 | 02:48 PM
NBTBRV8's Avatar
I think so. The rears bolt straight up but you would need to disassemble the fronts and bolt the rotor in to your turbo hat. I don't think there is much call for GT hats unfortunately.
Old Jan 28, 2012 | 11:08 PM
uschoice's Avatar
Has anyone here taken the rotors off a pccb GT2/3 and reassembled them to their turbo pccb hats, to make up for the different offsets?
Old Jan 29, 2012 | 02:53 AM
NBTBRV8's Avatar
And does anybody know what tension the fittings should be done up at?
Old Jan 29, 2012 | 11:36 AM
barchy's Avatar
barchy is infamous around these parts
are the same pccb gt3 and gt2 996?
regards
Old Jan 29, 2012 | 12:02 PM
NBTBRV8's Avatar
regards
Yes they are.
Enemy
Nov 10, 2015 08:01 AM
alevine
Nov 4, 2015 10:05 AM
TrackOne
Aug 20, 2015 12:56 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 18, 2015 03:41 PM
