Alternative sources for X73 suspension?
Did you have to get drop links to adjust for too much camber?
Thanks!
Henry
PS Did you sign up for the PCA Zone 2 @ VIR in March??
Drop links have absolutely nothing to do with camber adjustment.... Drop links connect the suspension to the sway bar..
I have PSS10'S with zero problems at GT2 height. X73 just like stocks are all Bilstein. That's why I went with "OEM" aftermarket. All you will ever need for street and "normal" track use, unless you are a track junky trying to shave tenths off and are running right upfront of the field. I also have sways. I would change nothing in my suspension department, as a DD and occasional track car, it is perfect. And I have only hit a bump stop on the rear once when I've hit a huge obscure pot hole at great speed on a **** road in Croatia when I had my car set ultra-low, lower than GT2 ride height, initially due to sag. If you fit PSS10’s allow up to 30mm sag after initially set height.
Sorry. Meant dog bones or whatever the pieces are in the rear that help correct camber.
I did have a bumstop issue when I first set my ride height. I had to rasie it up to minimize this problem. Other than sways and the PSS9's the rest is stock.
Make sure you spec the PSS10's with firmer springs. Renntrack has some posts on this I believe.
No to zone 2 to but yes to Potomac at Summit Main for April. Barry will also be coming. Jump in so we have a good turbo group
Maybe we can get Justin as well? Well Justin?
Thanks again!
+1 on the stiffer springs. Thats why I went with the 9ff pss9 years ago. I remember trying an OEM and Gemballa PSS9....WAY too soft.
I'll try and find out what my spring rates are as they work great for street and track!!
Ok so.....
Bilsteins + revalving + 450lbs Front springs and 650lbs back springs. (swift springs)
= Total cost ~4k for the set.
Makes me miss the X73s even more, haha. Damn.
Edit:
I think 2800 for Bilsteins, $250 for 2 shocks (since rears can handle up to 700lbs), and $400 ish for springs + shipping.
$3600?
Edit:
$3600?
Are there places to get firmed up PSS10s? Or do you HAVE to piece it together yourself? I also, would like to get it all-in-one kinda thing. Been really looking for a basic stiff suspension alternative. I had stasis tracksports on my DD Audi S4, 700 front, 900 rear springrates, and I loved it!
I have FVD PSS9s and love them. You don't need anything with PSS9s. Just an install by an experienced mechanic and forget about it. Set at stock to -1" ride height or so and you're good to go.
My understating is that the FVD version is a bit stiffer but is still BMW M3 smooth. A definite improvement over stock in both ride and handling.
Ari- where did you get your PSS9's from and who installed them? Nothing else needed, just bolt them on and go?
Ttpopo- how much can you lower using Bilsteins without having to add additional hardware? I'm with vr4henry, and don't want to go down the path of having to start changing out a lot of additional hardware. Mine is stock, but I'd like to lower it a little to get it looking like it's settled in good. Just changing out the springs doesn't get the best recommendations on this board, so I may go Bilsteins; after also considering X73. Any suggestions on where to purchase, and PSS9/PSS10 opinions?
