Coolant pipe repair - now required for DE!
  #46
Old 02-11-2012, 04:31 PM
jpflip's Avatar
  #47
Old 02-11-2012, 08:15 PM
K24madness's Avatar
K24madness is on a distinguished road
Originally Posted by sharkster
We do not weld these fittings, however we have done many of these cars with the fittings pinned as described in this thread. I'm not sure of the number (maybe Alex or James can help w/ that), but I'm sure in the range of 30-50+. Some were done 5-6 years ago, many have over 20,000-40,000 miles by now.
Zero have leaked to date as far as I know.
A GT3 came in last week for a 3.9L upgrade. A well-known shop performed a coolant fix for his car. Their solution was to weld the fittings. The car has had around a dozen track days. When we took apart the car we found this:
Tiny pinholes in the welds, that were probably invisible at the time of completion, lead to leaking coolant.
Every Shark Werks 3.9L, every 996 / 997 Turbo engine we've built since 2005, and many cars that dropped in for this repair are running the pinned pipes and none have leaked yet that I'm aware of. There are several Rennlist members who might not even be aware of how we do the fix and just about all are taken to a track.
In my opinion pinning the fittings makes more sense than welding. If you have a leak free joint the pin just takes the load off of the sealant preventing failure. Welding aluminum introduces a lot of heat. This can be a bad thing in some cases. The pressure of the cooling system is not high enough to warrant welding.
I know the above mentioned car owner and repair shop. Prior to the repair I suggested the shop pin the joints rather than weld them. The shop owners response lead me to believe he was looking out for his own interests rather than the best interest of the customer. The labor cost to clean and weld all the fittings exceeded 1k.
  #48
Old 02-11-2012, 09:34 PM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
I had mine welded a few months ago. One of the fittings is definitely leaking a small amount. Shop is looking at it now. Pinning seems like the way to go.
  #49
Old 02-11-2012, 09:49 PM
jpflip's Avatar
If you consider pinning the way to go. What do we do in the case like this one where the glue is not holding anything:
What we need also is the proper glue!
  #50
Old 02-12-2012, 03:02 AM
heavychevy's Avatar
I think I'm going to try and get mine pinned this week actually. Contrary to the antagonists of pinning, I haven't seen any evidence of pinning going wrong, but from here and the GT3 boards on Rennlist, I have seen at least a few instances of welded fittings leaking and being troublesome.
And what happens if the welds leak over time, another load of money to drop the engine and repair because you can't repair a weld with the engine in the car can you?
  #51
Old 02-12-2012, 06:11 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
They just finished welding mine yesterday. I will report if there are any leaks over time.
  #52
Old 02-12-2012, 08:18 AM
VAGscum's Avatar
One problem with welding them is the coolant manifolds are cast. Welding to any cast metal fixture can pose it's own set of issues. And aluminum is very sensitive to contamination when being welded. No matter how much you clean aluminum, a cast aluminum piece will have very small little voids for contaminates to live that can be sometimes impossible to clean out. Pinning would be the ideal fix in my book if the piece has not already come loose. Re-gluing and pinning seems like the fix if they come loose. I am not sold on welding for the above reasons.
  #53
Old 02-12-2012, 08:55 AM
Basic's Avatar
Basic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant future
Welding is the only absolute fix, problem is this needs to be done by an expert at welding aluminum. It also should be pressure tested but a pinhole leak will easily be fix with a quality radiator stop leak additive. Pinning may keep the fitting in but the real problem is the glue, which will still allow a leak.
  #54
Old 02-12-2012, 09:39 AM
John@SpeedTech's Avatar
I agreee that welding is the best absolute fix, you just have to be sure there are no pin hole leaks before reinstalling. If it doesn't leak, it never will. Pinning does seem a lot easier and will probably last forever, although it is possible a pin can get loose, at which point it is no longer pinning or in a worse case vibrate loose and spring a leak. With a proper weld, failure will just never happen.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
  #55
Old 02-12-2012, 09:41 AM
VAGscum's Avatar
Glue does not just give unless aadditional things like movement and heat initiates it. Pinning it stops it from moving or giving. The glue itself remains intact once the movement of the fitting is eliminated with the pin.
  #56
Old 02-12-2012, 09:47 AM
Glad to hear that welding is the best fix.
  #57
Old 02-12-2012, 01:01 PM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
Problem is they look like a ***** to pressure test because of all the different holes in the piece but if someone wants to send me their part and have some time on their hand, i can try to build something to pressure test the welds before putting them back on the car.
Otherwise, i will be making a kit next winter when i do mine and it is sure that i will weld mine, no way i will only use the pin method as when the glue gets bad, it will leak anyway, not blow but still...
  #58
Old 02-12-2012, 01:25 PM
pwdrhound's Avatar
It would be nice if someone had a few of the coolant manifolds available already PROPERLY welded + LEAK TESTED and ready to ship on an exchange basis with a core charge. With more and more of these ticking time bombs out there it could a lucrative deal for someone. This could be handled basically like John at Speedtech does it with the modifed OEM turbo intake manifolds. I think many people (including myself) would like to get this done but want it done CORRECTLY the first time with little down time. If I could have a set of the welded manifolds in my possession I would just drop off my car, get the engine dropped, coolant manifold swapped out and then just stick the old ones in a box and ship them back. Simple......
  #59
Old 02-12-2012, 01:29 PM
jpflip's Avatar
It is not very difficult for the small pipe behind the alternator or the one under steering pump. The problem is the three pipes on the water pump housing which also provide space for the cam housing oil pumps. This part is expensive. And also the filter housing which is not cheap.... But of course this is something a big shop should think about to have faster turn around time...And may be a better control of quality....
  #60
Old 02-13-2012, 08:15 AM
OldGrayWolf's Avatar
OldGrayWolf is on a distinguished road
The Shark Works fix will be accepted by OVR not only as an alternative to welding but a better approach. It is interesting to see that it is not just the pipe behind the power steering pump that fails but also one behind the alternator. Have any other tubes actually failed? We have had 3 failures , all on '04 GT3 cars and all were the pipe behind the PS pump.
Quick Reply: Coolant pipe repair - now required for DE!
