Trouble finding 315/25/19's. Anyone else?
Old Mar 15, 2012 | 02:41 PM
  #61
Zookie's Avatar
Originally Posted by texeck
I don't know anything about those tires - but thats a seriously good price. Must be d/c because they don't list that size on the Pirelli website. One company lists the diameter at 25" - so if thats right - its a steal of a buy.
Making me reconsider ordering the PS2's at $2000 all the way around.
thats because they are old stock, i had them last summer 2002 production date... really **** tires and look too small/streched on 11.5" Rim
I think next solution is 235/35 paired with 305/30.
Fortunatly i have a Almost New set of 235/35 & 315/25 PS2's to take me thru this summer.
Old Mar 15, 2012 | 02:50 PM
  #62
pwdrhound's Avatar
Originally Posted by Duff0000
I just called that number today and they told me its on national backorder! What gives!
She also stated that they can only see 4 weeks out in production range though. Bah.
Amazing, called them back today and just like you said, tires are not in stock. Maybe if we talk to them tomorrow then they will be. What BS...
Old Mar 15, 2012 | 03:41 PM
  #63
Zookie's Avatar
maybe we all shoould have a Confrence call when them and settle this for once
Old Mar 15, 2012 | 05:15 PM
  #64
Thales's Avatar
Thales has a spectacular aura aboutThales has a spectacular aura about
I just called the ebay seller. Those tires have a 2005 production date.
235/35 should NOT be paired with 305/30 in most cases. Check your brand's specs, but I see 760 revs per mi rear and 816 revs per mi front! (Pirelli specs for all) The front should be spinning at roughly the same speed or *slightly* SLOWER (as in OEM 996tt fitment). Running 225/40 fronts would be closer (798 rev per mi), but but the 235/35 315/25 combo is clearly the best @ 816 front and 824 rear...)
225/35 305/25 would be a good combo @ 822 front and 832 rear, but 2005 is pretty old...
Old Mar 15, 2012 | 07:23 PM
  #65
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
Originally Posted by scottrx7tt
i just bought some 305/25/19 tires, i think thats going to be close enough. Pirelli P-zero rossos, on ebay band new for $369 shipped per pair.
Good deal, but the rear of a TT quickest wearing tires i've ever run.-
Old Mar 15, 2012 | 07:35 PM
  #66
ajay's Avatar
ajay is infamous around these parts
Last week I had a blowout and needed to replace this tire. I called every discount tire within 100 miles. I eventually found a Michelin about 40 miles away.
Its a mismatched tire, but the car is on the road. Some of you other guys may have better luck, just takes hitting the phones !
-a
Old Mar 15, 2012 | 08:19 PM
  #67
Zookie's Avatar
its within 3% so it should be fine.
Old Mar 15, 2012 | 08:51 PM
  #68
Thales's Avatar
In the 235/35 305/30 combo, the fronts tires are spinning 7.4% faster than the rears! (816-760)/760=.0736
Old Mar 15, 2012 | 10:32 PM
  #69
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Agreed, that combo has the rears almost 3/4" taller than the fronts. That can't be good. A 235/40 would be a much better match.
Old Mar 16, 2012 | 07:24 AM
  #70
Zookie's Avatar
no idea which hole you pulled those numbers out of. If you use http://www.1010tires.com/TireSizeCalculator.asp
The diffrence is 816.6 Revs Front & 793.8 Revs Rear... thats 2.79% Diffrence... Should be fine...
but yes you guys are correct about 235/40 or 225/40 seems to be a closer Combo to 305/30
Old Mar 16, 2012 | 08:01 AM
  #71
Thales's Avatar
I used the specs for Pirelli PZero Rosso from tirerack:
http://www.tirerack.com/tires/tires....=yes&tab=Specs
The Pirelli tires are listed at 26.3" instead of the implied 26.2" based on quoted dimensions. Hence 760 revs vs 793.8.
I always use the listed specs for revs per mile as there can be significant variance in size from brand to brand and model to model.
Maybe we can find some super small 305/30s...
Old Mar 16, 2012 | 08:17 AM
  #72
Zookie's Avatar
Thats is true, my 235/35 Toyo T1R (RIP) was a smaller Tire than the Perilli P-Zero Rosso i ran last Summer, infact the Mich PS2 i have now is even bigger than the Rosso. Never Rubbed with the T1R, now my Fender Liner has a Hole in from the P-Zero i ran last year. Wonder how big that hole is going to get with the PS2 this summer.
Old Mar 16, 2012 | 09:28 AM
  #73
DucS4Rs's Avatar
DucS4Rs is infamous around these parts
Originally Posted by DHealy
I'm currently running 315/25/19 Invos with 235/35/19 Toyo Proxes T1R. No problems.
Thanks. I may give them a try.
I never imagined the psm would be so picky. I was way more worried about the tire size itself and the revs/mile adversely affecting the front diff thean I was a difference in traction from brand to brand.
Old Mar 16, 2012 | 09:48 AM
  #74
Nikolas's Avatar
Yes those calculators are just to get an idea. I was surprised at the differences between different brands. When it is off like the 235/305 combo, I would be more worried long term than immediate diff explosion. It is always best with this type of AWD system to get the diameters as close as possible. I always hear the 3% rule, however I've never seen that backed up by anyone from Porsche.
The stock tires are .1" off in diameter. The 235/305 combo is .7". That is a pretty big difference to me.
Old Mar 16, 2012 | 10:04 AM
  #75
pwdrhound's Avatar
Where exactly is this mythical 3% rule written? Does anyone have any idea??? Its like the lochness monster, people talk about it but nobody has seen it. Are there any people here that have used the 235/35/19 and 305/30/19 combo and killed their front diff as a result?
