What offsets for 19x8.5/19x11.5 WB
Some reported dangers of running 315s. Potential for messing up the differential AWD. Search threads for that tire size. Also wheel calculator same site as offset calculator. Google it; it is helpful.
I am learning from searching that there are differences between the 996 and 997 for tire diameter tolerances. Saw old post from Damon(tire rack) that 996 19" fitment should be close to 25.5 inch rolling diameter as possible front and rear. Is that correct 996 owners? Damon post from 3/07.
I think the ideal rear offset for 11.5 or 12" wheel is +37 and for the front +42. Does not rub with rear fenders rolled and sits fairly flush
#TeamAIM
#TeamAIM
the 225/40/19 and 305/30/19 are closer in ratio then the 235/315 combo
stock sizes are 225/40/18 and 295/30/18. usually when you upsize an inch you take 5 off the profile to keep overall diameter the same or close to stock.
#TeamAIM
#TeamAIM
Stay about 51-55mm front on an 8.5", and 45-48ish mm on a 12" rear.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
19x8.5+45
19x11.5+43
+37 is aggressive on a 11.5! I question the .5 increment on the rear wheel though? Why not step up to a 12" GT2 fitment or stick to an 11" ?
19x11.5+43
Oh and have fun finding tires for the 19" fitment. It is slim pickens to say the least and the ones currently available are expensive!
...But too tall to be sure they won't rub. 235/315 is the best combo for correct OD overall, and for OD difference between front and rear. Saty within 4% front to rear and you should be OK. 996 is more forgiving than 997.
. I will take a pic of new setup too....
#TeamAIM
#TeamAIM
^^Very nice! I am curious, why the 11.5 though? We usually go up straight to a GT2 fitment for the WB cars or stick to an 11". There is very little weight difference between an 11.5 and 12" barrel (1 piece or 3 piece).
That's why people are starting to run the 305/30 because the 315/25 is such a low demand tire, not many people are making it anymore. The 235/35 is readily available and will be for some time (oem fronts on 997tt)
Also with the 225/40 305/30 it does not rub at all at stock height, and with a set of pss10's the rear plastic fender wells needs to be pushed back a bit, and there is no issues, according to a friend with that setup.
I'm not surprised. That is a 26" wheel/tire combo. Too big for a 996TT.
