Front diff.
Old Mar 9, 2012 | 07:53 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Front diff.
I have just changed rear tyres - Michelin PS2 brand new - full thread. Fronts are half gone thread wise.
I can now definitely hear the front diff making whining noise when I go off throttle mainly 1st, 2nd and third.
Porsche Tech told me this is normal unless I change all four tyres.
WTF?
My front diff is definitely noisier (rattling wise) when I am on Michelins comparing to Pirellis but I never hand such pronounced whining. Diff is definitely working overtime...
Any of you guys having this?
Tanx.
Old Mar 9, 2012 | 11:33 AM
deckman's Avatar
May not be your diff. It could be your power steering reservoir. Does the noise continue when the clutch is engaged?
Old Mar 9, 2012 | 08:38 PM
Turbo Fanatic's Avatar
is it a high pitched sound?
Old Mar 10, 2012 | 01:18 AM
Terminator's Avatar
No. Sounds like a bearing sound. Will record from benath the car today.
Old Mar 10, 2012 | 05:57 AM
Terminator's Avatar
Here we go; 1st gear up to 4K rpm then clutch in/out and off throttle. It seems it is coming from the front diff. Is it possible that tyre circular difference front/rear would put front diff under such strain to make such noise?
http://www.communicormedia.com/Porsc...-frontdiff.mp3
Old Mar 10, 2012 | 09:32 AM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
What are the tire sizes?
Old Mar 10, 2012 | 09:40 AM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Does your PSM activate at all when you're driving?
Old Mar 10, 2012 | 11:11 AM
Terminator's Avatar
Stock. 295/30/18 and 225/40/18.
Old Mar 10, 2012 | 11:12 AM
Terminator's Avatar
No it does not. Works normally.
Old Mar 10, 2012 | 11:15 AM
Terminator's Avatar
I am down to front diff or bearings in gearbox. My Porsche tech tells me two gearbox bearings can be swapped without dropping engine and gearbox? Aperently some lids open on gearbox and you change frommthere? Which bearings are those?
Old Mar 14, 2012 | 08:43 AM
Terminator's Avatar
Thanks to sql_pl...
Same problem here. So if you hear any whining (not originating from your wife or girlfriend) but from the gearbox, don't delay! Also inspect those mounts!
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
