How much driveshaft movement in CV joints?
Old 03-20-2012, 07:45 PM
superchicken's Avatar
superchicken is on a distinguished road
Grab one of the rear driveshafts and try to slide it back & forth toward the wheel and the transmission, in/out of CV joints on each end. How much does it move (or how much should it move?). It is supposed to move some by design. I am trying to determine if mine has too much play in the direction parallel to shaft. Thanks.
Old 03-21-2012, 07:22 AM
sweeney186's Avatar
sweeney186 will become famous soon enough
Yes there will be some movement in the direction mentioned,the shaft has to be able to swing in an arc vertically.There should be less movement towards the front & rear of the car(horizontically)
Old 03-21-2012, 09:49 AM
John@SpeedTech's Avatar
It's hard to tell if they are worn, as there is some movement. I had some drive line play a few years ago and had them checked. I was told they were fine. I said replace them anyway and the new ones really tightened things up. Problem solved.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Glasgo
11-30-2015 02:37 PM
Ronny-
09-30-2015 07:30 PM
Quick Reply: How much driveshaft movement in CV joints?
