Turbo Outlet Size and Intake piping (post-turbo)
Hi John,Thanks for your info..I was just mentioning it as a general statement as far as air flow basics,which applies more so to non turbo's..I agree some what with your above statement....Yes,if everything is bigger and at a higher boost level it will make use of more volume but going too big in certain areas may also hurt the velocity of the charge....
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
Well....thats just it! Most people expect that bigger is better. and it is a good sales pitch. however you are messing with velocity of air flow which at a certain point is important. not to mention the constant upsize and downsize creates eddies and turbulence which further disrupts air flow and velocity. i agree sometimes bigger is better just cuz it looks or sounds cool.
however the fact is that uniformity and smooth transitions and turns are the goal.
Flow=Pressure/Resistance
I mean what is wrong with you Peyton Manning? At least I have offered some information based on science unlike you and you "I'm 99% sure" crap. I actually do have some limited expertise in flow dynamics, but no Peyton Manning.
I'm not saying no aftermarket parts increase performance. Obviously aftermarket turbos are great as are other items. If your turbo outlet is 2 inches you can't flow more than what that allows out. even then it needs to be a relatively laminar flow. Your smallest diameter in the entire system is your limiting factor.
A 3 inch y pipe is a gimmick and you just don't need it. And while the diameter of even the OEM stuff is fine I expect it could be smoothed out to some degree. While I'm not going to sit down and do any math I expect 2.25 is just fine for any give 2" turbo out.
You clever little man you, you discovered that everything that is not OEM is a scam and does not actually increase performance
Hey,After all these theories of velocity , volume and size restrictions in the intake plumbing>>I just saw a Intake Plenum from a 997.2 turbo and guess what??
Porsche made the plenum a smaller diameter in the part of the T that connects to each bank of cylinders...Its smaller diameter then our 996 Turbos and smaller then the TB diameter...The Porsche tech says they did the same on the new 997 GT-2...
Powell I asked a simple question that no one seems to have a good answer for. Why don't you answer my question????
You make a ton of horsepower on stock y pipe. What were your turbo outlet sizes when you used stock intake? What are they now?
Nobody has a gun to you alls head for this. I'm a firm believer in seeing things done myself and not trusting EVERY word spoken. Just like people thinking the a SET amount of boost will a blow a number regardless of turbo size is beyond me.
Regardless every time you post a "question" you just look for a reason to argue and same with pumptech. If this game is so easy please just get it done and shut everyone up. I can tell you from experience there is a point you hit where it's not so simple anymore.
Just getting tired of it being made like people are idiots and just don't have it figured it like you all.
I made 1150rwhp on C23 at 38psi with some boost related issues on a STOCK 997TT T-Pipe and TB. I added a IPD and 82mm TB but we are at a point where we are maxing out the GTX3582's with an .82 a/r. 1200rwhp would have been the cutting point but on C23 vs E85 I'd rather have 1100rwhp on E85 then 1200rwhp on C23 because drivability is better. My plan for the weekend is to drain the rest of the C23 and replace plugs and some couplers and go back to E85.
I'm making a full 415 at the flywheel according to Porsche. And I don't ask questions looking to argue but do love to argue if there is discussion to be had. In fact, I have not really posted many technical questions and have really only argued comments of jitsu (who was just chewed up and spit out in the EVOS IC thread for making crap up) who only regergitates facts and to a lesser extent BHT because he takes jitsu's position.
But like bad107 said nobody has an answer that supports the use of anything larger than the turbo out. While I am no physics major, I not only have significant experience in flow dynamics but have taught classes on it in the past as it relates to blood flow. I think I prompted bad107 to ask this question after teasing him about his big pipe. I'm not claiming anything is easy. Most anything is easier said than done!
It's not theory but fact. Il say it again. You cannot flow more than the smallest diameter in the entire system allows. This unfortunately for most is the turbo out at 2" or less. Based on this you don't need anything significantly larger than this throughout the system. Anything large enough to fit the lip of the turbo out is enough. If you want to add a little diameter (2.25) for friction loss seen from the length of the system so be it. But remember air coming out of IC is denser than going in so I expect this negates that need. Again keeping thing smooth, free of size transition, and laminar is key!
But to think that you need 2.5" hoses and a 3" Y pipe is just money down the tube (no pun intended) and at a certain size may even be detrimental to flow and velocity. Nobody has to take this to the bank but it's food for thought before making upgrades and expensive purchases.
The smaller piping is likely causing turbulence thus slowing down the flow. It's like the turbo outlet--they are funnel shaped expanding to a larger size to the exhaust system to reduce turbulence. It's clear the larger pipes make a difference on bigger HP set-ups but if people want to put on smaller ones, then that's OK too.
so many different opinions!!
the only major restriction i noticed on 996 is the inlet turbo pipes. besides that is good for MAX 580to700hp. stock to A28 TURBO. YES, can you improve certain thaings but at what price. is it cost effective for what you want. remember people are trying to sell stuff not at your best interest and tell you what you want to hear. I do a lot of R&D thay are parts out there that i can't mention on the forum just doesn't work. i also made 1200hp on E98 at 32psi on a AIR COOLED MOTOR ann rand 169mph in a 1/4 236.6 in one mile at 20 psi so i'm not just talking. SO BUYER BEWARE!
I agree in that the size of the turbo (ie, the volume of air) is the most relevant. My car made 600whp with 18g's, 93oct pump gas, injectors, exhaust and 100% meth. ALL stock piping, IC's, airbox, air filter and throttle body. The only gain the bigger piping and IC's got me was quicker spool (by about 600rpm), which equated to more power and tq sooner, but NOT more peak power or TQ overall. So yes, the piping helps, but will not help you become a dyno king. And again, this is with 18g's. I'm sure this would change with a bigger turbo with more air delivery potential...
I think it's been proven to be almost identical. I made a little under 20 more whp on the same dyno, same day, between pump/100%meth and MS109 and 50/50, at the same boost and timing. Now, I think we should all agree that MS109 is a better option, performance wise, as it comes out of a can and is consistant, whereas 93oct differs in cleanliness from station to station...
