Problems with seat memory-Somehow a tech working on my car programed the "key" memory
Old Mar 25, 2012 | 03:14 PM
s4gotten's Avatar
s4gotten has a spectacular aura abouts4gotten has a spectacular aura abouts4gotten has a spectacular aura about
to my seat in a very uncomfortable position. I have successfully reprogrammed the "1" and "2" seat settings, but even though I have the key in the ignition at the time, the "key" seat setting wont retain the position I program in. Its super annoying because everytime I unlock the car the seat moves so far I have to correct it just to be able to depress the clutch. TIA
Side note: does anyone have a link to an old thread called "Things I never knew about my 996 turbo" or something along those lines? I believe it was a long thread full of little tricks and easter-eggs about our cars. Thanks again
Old Mar 25, 2012 | 03:19 PM
dragonman4's Avatar
dragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond repute
I was under the assumption that the driver seat memory settings would save with the specific keys. When you say you successfully reprogrammed the 1 and 2 settings, you held down the memory button at the same time as the 1 and 2 buttons to save it to memory? I recall there is a button with the picture of the key on it as well, maybe try holding that down with the 1 and 2 to see if it will save to the key. I would pull out the manual but I don't have the book with me.
Old Mar 25, 2012 | 03:35 PM
s4gotten's Avatar
Thanks for the reply. There is indeed a key button next to the 1 and 2 buttons and its supposedly (according to the manual) programmed the same way as the 1 and 2 keys, but after I program it, it wont store the new position, as the 1 and 2 buttons did
Old Mar 25, 2012 | 06:01 PM
Twinturbofan's Avatar
Twinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud of
I have the same problem. #1 button is programmed, #2 button is programmed but "key" button will not hold program. When I unlock car with remote, seat goes all the way back. Dealer said it is a programming issue and even they have to hook up their durametric and just play with it until they get it right. Not very reassuring that they can actually correct it so I have been just living with it. Please post if and how you get your corrected.
Old Oct 15, 2012 | 01:49 PM
koolkat1973's Avatar
koolkat1973 is infamous around these parts
For those with memory seat feature, can you let me know whether the seat memory numbers are illuminated at nighttime. Mine does not - so I'm wondering if the memory unit itself is bad. Thanks.
Kiet
Old Oct 15, 2012 | 03:09 PM
Slider's Avatar
Each remote can have a seat memory position assigned to it - up to 4 different keys.
To store the memory for a key - turn ignition on, set the seat position to what you want (put the car in reverse if you want the passenger mirror to move down when in reverse). Now, here is the trick - Press "M" first and hold while you then press the "Key" button at the same time.
The stored position should automatically be recalled whenever you unlock the door or trunk.
Old Oct 15, 2012 | 03:14 PM
Slider's Avatar
You can also clear the "Key" stored position by pressing the "Key" button and person 2 button simultaneously for at least 5 seconds.
You can test if the "Key" memory was set by pressing the "Key" button when in the car with the ignition on. If the seat moves, it must have been set. If the seat does not move - just move it a little and then press the "Key" button. If it still doesn't move, you have confirmed no memory was set.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 21, 2015 06:34 AM
saline
Aug 19, 2015 12:25 PM
