PSS10 vs Stock
Old Apr 10, 2012 | 01:06 AM
mike4s's Avatar
mike4s is infamous around these parts
PSS10 vs Stock
Hello to all
Any opinions for pss10 on a 2003 4s?
Im not interested to lower the car that much as i am interested to improve the ride quality.
Old Apr 10, 2012 | 02:13 AM
Charsiu's Avatar
Charsiu is infamous around these partsCharsiu is infamous around these parts
I used to have pss9 on my e46 M3 and it was wonderful street suspension.
But it is way too soft for track use.
I believe the PSS10 provide better handling and if it is just as good (if not better) as pss9, I think they will be great on your car, and probably a lot better than stock suspension (in fact, most upgrade are better than stock setup, lol)
Old Apr 10, 2012 | 02:25 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Originally Posted by mike4s
Hello to all
For street and occasional track work, (not chasing milliseconds) night/day. Just do it.
Old Apr 10, 2012 | 03:13 AM
mike4s's Avatar
I sit in a 996 c2 with kw3 and noticed that although adjusted at full stiff mode car didnt bounce at all. Should i expect something like that?
Old Apr 10, 2012 | 03:18 AM
Terminator's Avatar
Similar. Comparable coilovers. One over the other - preference only.
Old Apr 10, 2012 | 08:00 AM
Guybrush's Avatar
Guybrush is infamous around these parts
My OEM ROW -suspension went to the bin on thursday and PSS10 went in. Much firmer ride, sharper turning, without sacrifying ride comfort. I lowered 1cm from ROW ride height. From carage floor to front and rear wheel arch center the ride height is now 65 cm. I have damping setting front 6 and rear 4. I will set front to 7.
I will have to have aligment re-checked, after suspension job car started to pull slightly to the right when releasing steering wheel. I hear it is common when lowered with these cars especially when there is camber on the road.
Old Apr 10, 2012 | 08:17 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
I had stock to begin with and switched to PSS10s when I added power. I only lowered my car by about 1/2". Two things I noticed the most... roads that felt bumpy before don't feel bumpy no more. Quick lanes change at high speed feels much more planted/stable.
Old Apr 10, 2012 | 08:40 AM
Guybrush's Avatar
Which is your choice for PSS10 damping settings rear/front?
Old Apr 10, 2012 | 08:47 AM
MY996TT's Avatar
I used to do 5/6 and changed to 7/8 for the last 12 months since I have been doing a lot of twisty roads. 7/8 is still comfortable... no complains from wifey.
Old Apr 10, 2012 | 08:49 AM
MY996TT's Avatar
Guybrush,
Not sure why you do the front higher than the rear; most shops that I know do rear higher due to the understeer of our cars.
Old Apr 10, 2012 | 08:59 AM
Guybrush's Avatar
Guybrush,
That was a recommendation I was given by a trusted forum member on rennlist. Given the settings that I have now, the front seems too bouncy. I will experiment different settings soon when my car goes in for re-aligment.
Mike4s sorry for hijacking your thread.
Old Apr 10, 2012 | 09:09 AM
MY996TT's Avatar
Please keep in mind that you should drive your car for a couple of weeks and let the coilovers settled before going to the alignment shop. Enjoy!
Old Apr 10, 2012 | 10:35 AM
dreamtripper's Avatar
dreamtripper is infamous around these parts
What other suspension components need to be addressed when installing PSS10s? Wouldn't putting on the PSS10s and lowering adversely affect camber?
Old Apr 10, 2012 | 11:02 AM
Guybrush's Avatar
Original struts with spring tops need to be reused.
Old Apr 10, 2012 | 02:19 PM
Terminator's Avatar
That's a dangerous setting. Who recommended this to you? Cars should be slightly lower at the front. As you accelerate they lift at the front. I would be really concerned on high speed runs. You really don't want front lift at anything above 150mph unless your intention is to pretend you are an aeroplane and actually take off!!
