Coolant smell
Old Apr 15, 2012 | 11:49 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Coolant smell
I can smell coolant on cold days. I have no leaks and my coolant settles just under min mark no matter how high I top it up. Car is not overheating and is dead on 80 degrees. I had my bumper off and cleaned the rads and have seen no signs of leaking.
Any of you have this?
Should I pressure test and investigate?
Old Apr 15, 2012 | 12:35 PM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
I had this twice -first was the overflow tank that showed a little drip on the floor. 2nd time was the water pump began to weep and burned off before hitting the floor. The waterpump will show some discoloration/water stain if it's the case. Good luck and keep us posted.
Glasgo
Nov 30, 2015 02:37 PM
Jd1368
Oct 16, 2015 09:48 AM
freddiemac
Oct 7, 2015 11:05 AM
XLR82XS
Oct 5, 2015 07:02 AM
flewis763
Oct 4, 2015 04:14 PM
