1st gear is gone
Old Apr 23, 2012 | 03:05 PM
r71's Avatar
r71
r71 has a spectacular aura aboutr71 has a spectacular aura about
1st gear is gone
Anyone know of a good tranny rebuilder in Atlanta area? It's for a 02 TT.
Old Apr 23, 2012 | 03:58 PM
Tim941NYC's Avatar
You going to ship the trans? Or do a one stop shop?
Old Apr 23, 2012 | 07:49 PM
r71's Avatar
r71
One stop would be preferred, but hey, whatever works at this point.
Old Apr 23, 2012 | 09:11 PM
VAGscum's Avatar
That sucks, man
Okay, 1st gears don't just fail. What happened? Driving style? Not trying to say you caused it. Just curious of the circumstances? Was the old shifter setup causing missed shifts? Were you doing 1/4 mile runs? Or missed shift?
Old Apr 23, 2012 | 09:16 PM
Dr_jitsu's Avatar
I had mine done by Brian Copan in Ohio....its worth shipping as he is one of the best in the country.
Old Apr 24, 2012 | 06:02 AM
r71's Avatar
r71
Welp, here are the symptoms. Going from neutral to first: press the clutch, put it in first, release the clutch, grinds big time. The workaround is: put it in second, then for to first, now everything is fine. I described the problem and dropped it off. At first they thought it was the first gear synchro clip, then I get a call saying first is gone. If that's the case, would I've been able to drive normal? As long as I go from second to first, no issues and nothing feels different. Oh, it also doesn't pop out of first.
Old Apr 24, 2012 | 06:05 AM
r71's Avatar
r71
Originally Posted by VAGscum
That sucks, man
My buddy who I got the car from said the grind started when he put the aftermarket short shifter in. So I changed it out with a 997 shifter. 997 shifter felt much better but the 1st gear grind is still there. I don't have the original so cannot compare to see if the shifter is the problem. No miss shifts or drag strip. Car hasn't been driven very hard.
Old Apr 24, 2012 | 06:07 AM
r71's Avatar
r71
Originally Posted by Dr_jitsu
I had mine done by Brian Copane in Ohio....its worth shipping as he is one of the best in the country.
Can u post contact info, just in case.
Old Apr 24, 2012 | 06:56 AM
Dr_jitsu's Avatar
740.593.8936
Where is the icon for enlarging font, btw?
Old Apr 24, 2012 | 07:11 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
Yes!
Old Apr 24, 2012 | 09:29 AM
if grind started after an aftermarket shifter. that means he did not properly mark teh shifter cables when isntalling that ALSO means you probably installed them the same way when changing to 997 shifter (incorrectly). you might not be fully in 1st gear - thats why its grinding or that could have cause a failure in the trans itself.
#TeamAIM
Old Apr 24, 2012 | 10:54 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Sorry man that sucks
Old Apr 24, 2012 | 11:59 AM
Tim941NYC's Avatar
Plus 1
Old Apr 25, 2012 | 06:09 AM
r71's Avatar
r71
This is true. But the 997 shifter was installed with the tool in place. With the tool, you just lay the cables down while the shifter is aligned in a neutral position.
SlinginHoss
11
Oct 8, 2025 05:16 PM
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
panas001
Sep 27, 2015 02:51 PM
