can someone share a part #
i have codes, p1126/1128..many have seen my thread, i have smelled gas...i thought i would check under access panel to see if any gas had leaked there, low and behold 1 of the nipples, assume NOT under pressure, was broken off and crudely expoxied back on, and btw was separated from the cap. lucky me....anyone know the part #
tia
tia
Thank You....John from protosport thinks I have found my code throwing bogey man, the nipple that was broken off and poorly epoxied back on(was falling off) is tank vent line, an open vac leak....hope so
