Tech Info On Intercoolers
Old May 31, 2005 | 01:16 PM
whorespower's Avatar
whorespower is infamous around these parts
I had a knowledgeable tuner swear to me that there was no difference between intercoolers on a regular turbo and GT 2...
He went further to break down the capacity of each and showed me a side by side comparison.
Is the only difference the part number??
If so can anyone recommend someone who makes custom intercoolers?
Old May 31, 2005 | 01:28 PM
Ruiner's Avatar
I believe the claim is that the GT2 has 10% larger intercoolers, but who knows. It is a shame that we can't do a FMIC (front mount intercooler) setup to really maximize the air flow. I do not believe that the rear "openings" flow enough air to maximize the use of the intercoolers, but who knows.
I would like to see some flow rates before I say that for sure, though.
Old May 31, 2005 | 01:33 PM
03-turbo911's Avatar
Senior Member
Ruiner, intersting what you said about the side slots. Not alot of people explore that avenue.
The X50/GT2 intercoolers are different and they are larger with fins that stick out instead of being smooth.
For custom intercoolers, you can ask S-Car-Go racing or the Speed Gallery to make a custom set for you. You can ask CJV or Craig about what they had done.
Old May 31, 2005 | 10:28 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
The x50/GT2 intercoolers are slightly different, and slightly larger, than turbo intercoolers. See e.g., http://www3.us.porsche.com/english/u.../leistung.htm.
This is a photo of a x50/GT2 intercooler:
This is a photo of Speed Gallery's modified intercoolers -- SG modifies the end tanks to remove air flow restrictions:
Craig
Old May 31, 2005 | 10:48 PM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
996TT intercoolers are different than GT2 intercoolers, as they have rasied cooling fins.
Other than that they are the same.
Old May 31, 2005 | 11:02 PM
cjv's Avatar
cjv
Moderator
Re: Tech Info On Intercoolers
Well that settled one thing. That tuner isn't knowledgable.
Old May 31, 2005 | 11:06 PM
cjv's Avatar
cjv
Moderator
One of the finest made is by S Car Go Racing.
Old May 31, 2005 | 11:17 PM
cjv's Avatar
cjv
Moderator
These intercoolers are 87+% efficient.
Old Jun 1, 2005 | 05:10 PM
I appreciate your input. Were any mods needed to make them fit or are they the same size as stock?
Old Jun 1, 2005 | 05:15 PM
cjv's Avatar
cjv
Moderator
Re: Thanks
Yes, there was some mods. The stock intercooler is 75% efficient. The GT2 intercooler is 77+% efficient.
Old Jun 1, 2005 | 05:21 PM
Just checked the S-CAR-GO site and they don't appear to be on there.
Do you know how much it costs for the intercoolers and carbon fiber intakes?
Is it recommended to do the injectors at the same time??
Thanks again
Old Jun 1, 2005 | 05:37 PM
Erik@Cargraphic's Avatar
Erik@Cargraphic is infamous around these parts
RS Tuning Intercoolers
Here a partial picture of RS Tuning's Intercolers.
On mildly tuned 996tt's HP gains of around 20HP were seen. On vehicles with a higher level of tuning (big turbos, etc) gains around 50 HP were realized.
They are using a super efficient core that is used in the aviation/aerospace industry!!!! (im quoting from the web site)
Up to 22 degree centigrade drop in inlet temp.
Old Jun 1, 2005 | 05:52 PM
Craig's Avatar
I looked into the RS Tuning intercoolers a few months ago. I forgot the exact price, but it was over $10,000.
Craig
Old Jun 1, 2005 | 07:11 PM
Ruiner's Avatar
I come for the Japanese turbo way of thinking: With front-engine cars, it is easy to throw one large, single intercooler in front of the radiator in order to maximize the air flow efficiency. Basically, the more air (the cooler the better) that you can flow over the intercooler at a fast rate (the front bumper of the car having a huge opening for that air to pass through in a front mount intercooler setup), the cooler (and thus more heavily packed with Oxygen) the charge that enters into the engine via the intake plenum. Cooler air has more oxygen = more horsepower. Your efficiency goes up and the turbos are maximized. Of course, as your intercooler size goes up, so does turbo lag (to an extent). It is a give and take, really.
Think about it this way: Would you rather have two small radiators that get medium air flow in order to cool your engine or would you rather have one large radiator that has heavy air flow to cool your engine?
The choice is easy. The idea is to figure out how to maximize the air flow over the intercoolers in a 911 turbo. Once you do that, you can then experiment with intecooler sizes and depths.
Here is something to think about: Is that air that flows through the side "openings" greater than or equal to the air that flows into the oil coolers via the ducts in the front bumper? My initial thoughts would lead me to say no, but I cannot be sure until I see actual flow tests. Of course, we can't run intercooler piping all the way to the front, but you get the idea of how limited our cars might be in terms of intercooler efficiency.
Old Jun 1, 2005 | 07:17 PM
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
Originally posted by Ruiner
I come for the Japanese turbo way of thinking: With front-engine cars, it is easy to throw one large, single intercooler in front of the radiator in order to maximize the air flow efficiency. Basically, the more air (the cooler the better) that you can flow over the intercooler at a fast rate (the front bumper of the car having a huge opening for that air to pass through), the cooler (and thus more heavily packed with Oxygen) the charge that enters into the engine via the intake plenum. Cooler air has more oxygen = more horsepower. Your efficiency goes up and the turbos are maximized. Of course, as your intercooler size goes up, so does turbo lag (to an extent). It is a give and take, really.
The choice is easy. The idea is to figure out how to maximize the air flow over the intercoolers.
same here man , i came from the japanese style tuning... if we do manage to fit a big fmic how are we gonna be able to run the air back to the motor,,, the length of the pipes will ensure pressure drop were pretty much screwed and have to live with the side/rear ic's...
i have seen gemballa and other tuners putting the ic on the rear decklid of the cars but i thikn kpv has had problems with it, they are showing air flow drops.. or pressure drops.. jsut cant remember what thread it was...
