KW V3 + RSS Top Mount Issue
Old Apr 29, 2012 | 10:42 AM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
Hi guys,
Putting these together this weekend and need some opinions... I think I'm missing a spring collar or something.
Where the mount hits the spring, it will slide around if I put lateral pressure on the spring. Thoughts?
Pics below of spring in correct position, then another pic after I push it.
Old Apr 29, 2012 | 10:56 AM
vr4henry's Avatar
Nevermind. Looks like I forgot to resuse the giant gold washer from the top of the old strut. Seems centered and sturdy now.
Old Apr 29, 2012 | 10:57 AM
VAGscum's Avatar
There should be something that will go between the upper spring perch and the mount. Or maybe a cone type spring hat to replace the one you have. seeing as the upper mount does not have an angled portion for the spring or spring mount to contact, you have make sure the spring perch or spring does not touch the upper strut mounts. Attached is a picture for example. I hope this helps.
Old Apr 29, 2012 | 11:02 AM
vr4henry's Avatar
Here's what it looks like afterwards...
Look OK VAGScum?
Old Apr 29, 2012 | 12:54 PM
VAGscum's Avatar
Look OK VAGScum?
When you pivot upper strut mount around, does the spring or adapter hit the mount? Or is it firmly seated on the strut mount? Ideally for a monoball mount you should be able to pivot it around without contacting anything other than the bearing mounting point where it bolts. Some setups allow for the upper spring perch to rest on the mount, but most of the Porsche ones I have seen do not.
Old Apr 30, 2012 | 08:05 AM
vr4henry's Avatar
It pivoted around cleanly after I added the big washer into the sleeve. Hopefully I did all that properly
Here's what it looks like now.
Old Apr 30, 2012 | 12:39 PM
vr4henry's Avatar
Well, damn. Glad you saw this and glad I only moved it a few feet. I'll call in a couple mins.
Thanks!
Henry
Old Apr 30, 2012 | 12:42 PM
Turbo Fanatic's Avatar
That's damn low!
Old Apr 30, 2012 | 01:01 PM
vr4henry's Avatar
Originally Posted by ari
That's damn low!
They're gonna get higher after I add the proper spring perch adaptors, haha.
Not RSS's fault btw -- I bought them 2nd hand. Many thanks to Mike for spotting this thread.
Henry
Old May 5, 2012 | 06:45 PM
vr4henry's Avatar
Huge thanks to Mike, Bryan, and Nathan at RSS. Got me the adapters ASAP and talked me through the install.
Here's the dirty beast after I finished up!
Old May 5, 2012 | 07:46 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
hows the ride on the street? I've heard with KW v3's (depending on the setting) it's more compliant and better ride than OEM?
Old May 5, 2012 | 08:25 PM
vr4henry's Avatar
No street riding yet, towing it to shop Thursday for align/tune. I figure I'll let the pros get me a street setting since I have no idea what to expect from it I will do a full report when I get it back. I do lots of street driving and trying to do ~12 DE days a year so hopefully this can handle both!
Henry
Jul 29, 2019 11:13 AM
