Yikes!! Smoke!!
Old Jun 1, 2005 | 08:34 PM
Raza's Avatar
Raza is infamous around these parts
Yikes!! Smoke!!
I pulled my car out of the garage to get my bike out today. Didn't notice anything at that time. The car sat in the driveway for a few hours. When I started it back up to pull into the garage, A HUGE puff of white smoke came out. What's up with that?
Yesterday, I was out cruising some back country roads with a buddy following me. I came accross a long clear road and decided to gun it. My friend said there was a puff of black smoke that came out. Is this a normal occurance in turbo cars? I noticed that my old Nissan would also do this some times.
Any thoughts?
Thanks.
Old Jun 1, 2005 | 09:16 PM
GENERAL LEE's Avatar
Senior Member
GENERAL LEE is infamous around these parts
The white smoke is normal as flat 6 engines will occasionally do this at startup. The black smoke probably means you are babying the car too much and need to floor it more often.
Old Jun 1, 2005 | 09:22 PM
Raza's Avatar
ooooh.. I like the second comment! I guess I'll have to hit it more often
hehehehehe
Old Jun 1, 2005 | 09:35 PM
Ruiner's Avatar
White smoke: The engine is a flat-6, so a bit of oil can sit in the head and quickly burn off when you start the car - normal.
Black smoke: Typically the results of carbon deposits and running slightly "rich" on your fuel trim - normal for a turbo car.
You need to run a few WOT runs at high revs to clean the carbon deposits out.
Old Jun 1, 2005 | 11:34 PM
gilzen's Avatar
gilzen is infamous around these parts
well I just "decarbonized" my car coming home on the 60 freeway.
Old Jun 2, 2005 | 06:48 AM
Raza's Avatar
"Decarbonized". hahahaha
Thanks guys, I feel so much better knowing that my car is fine and that I need to drive it harder ; )
Jd1368
Oct 16, 2015 09:48 AM
alpha motoring
Oct 2, 2015 12:04 PM
