MAF Numbers
Old May 30, 2012 | 01:27 PM
TimAZ's Avatar
TimAZ has a spectacular aura aboutTimAZ has a spectacular aura aboutTimAZ has a spectacular aura about
Hi Guys,
Even with my shop not being sure about MAF, I have ordered a new one. I seemed to have bought someone elses problem car. I hope the Secondary air and cat eff. codes will clear with the new MAF...and maybe the PSM/ABS codes, but I don't think so.
Old May 30, 2012 | 08:57 PM
TimAZ's Avatar
Question
Thanks to everyone who helped me with this. I think the Durametric is the best tool anyone can have when you own a modern Porsche. I used it again today and found I have dead O2 sensor after the cat. This should fix the cat eff. code I have when I replace it tomorrow. I still have a secondary air code...maybe it will fix it also...any thoughts?
Old May 31, 2012 | 05:07 AM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Look at changing the front psm looms there is a chance that they were damaged with the pss9 install, this may be the reason why you are getting the psm abs light. Should be cheap.
Old May 31, 2012 | 01:29 PM
TimAZ's Avatar
Unhappy
I have put this on the lift and looked at all of the wiring 8 or 10 times by know and haven't seen anything at all...With the evap problem now fixed I guess I will start changing other parts to fix this...
The Bogg
May 22, 2018 08:19 PM
BLKMGK
May 31, 2016 04:32 AM
Stuart@VelocityAP
Sep 21, 2015 12:27 PM
maroli
Sep 15, 2015 07:07 PM
Suds26
Sep 2, 2015 01:33 PM
