Wheel Spacers - Any ill effects?
Old Jun 1, 2012 | 02:23 PM
bushman66's Avatar
bushman66 is infamous around these parts
I wanted to grab some spacers to help pull the wheels out a bit to fill the fenderwells a bit better. Stock turbo twists on a 2001.
Will adding spacers cause any negative effects (ie weird handling, braking issues, wheel bearing wear, etc)?
What size spacers should I be looking for front and rear? I don't want to roll the fender lips...
Thanks!!
Old Jun 1, 2012 | 03:14 PM
damon@tirerack's Avatar
Moderator
7mm front, 15 rear are very common and don't seem to bother the cars. I have them both if interested. Give me a call.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Jun 1, 2012 | 04:57 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
15mm all around is the way to go! I have mine for sale right now if your interested... PM me
Old Jun 1, 2012 | 05:52 PM
bushman66's Avatar
Do the 15's rub in the front? What about at full steering lock and rebound?
Old Jun 1, 2012 | 06:47 PM
'02996ttx50's Avatar
7mm front. 15mm rear. Next best thing to 9x12 wheels. You'll love the stance, especially if you drop the car 40mm. No issues whatsoever.
Old Jun 1, 2012 | 07:26 PM
LiNks's Avatar
15mm all around no rubbing at all not even with a drop at full steering lock and rebound... they fit like a glove, some even go bigger in the back depending on how aggressive you want to get
Old Jun 1, 2012 | 09:11 PM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
I also have 15mm all around with 997TT wheels. I do get some rubbing on inner portion of wheel wells at full lock. It is minor and I obviously try not to go full lock to avoid it. I started with 7mm fronts (no rub), but IMHO 15mm looks much better.
Old Jun 2, 2012 | 07:29 AM
landjet's Avatar
What size tires are you guys running with 15mm spacers at all 4 corners?
Old Jun 2, 2012 | 08:02 AM
LiNks's Avatar
997tt wheels are a different sizes and offsets then stock 996tt wheels.
Tires were OEM sizes when I had 15mm spacers on.
Old Jun 2, 2012 | 11:13 AM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
+1 perfect on the track as well
Old Jun 2, 2012 | 02:48 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
WOW! This is the way the $160 000CDN car should of came from the factory. Transforms the car!
Old Jun 2, 2012 | 03:46 PM
ASLAN's Avatar
True! Stock 996TT hollow spokes are 18" rims:
8" x 50 offset in front with factory 225/40 rubber. Rears are 11" x 45 offset in rear with factory 295/30 rubber.
My 997TT stockers are 19" rims:
8.5" by 56 offset in front and 11" by 51 offset in rear. And I guess I should have mentioned originally, I have 235/35 fronts and 315/25 rears.
Old Jun 3, 2012 | 12:47 PM
AutoTalent2's Avatar
AutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to all
As long as the spacers are intended for your car with the correct length wheel bolts, there are no issues. Porsche uses and offers spacers but are limited on sizes compared so others.
Old Jun 3, 2012 | 02:02 PM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
Does Porsche officially make a 15 mm version fro the 996 TT; I know they do 5 mm ???
Old Jun 3, 2012 | 02:03 PM
RCH's Avatar
RCH
If so Part number would be appreciated
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
