P1109 Code question, and 9110 too
Old Jun 1, 2012 | 09:21 PM
drug delivery's Avatar
drug delivery is infamous around these parts
I recently bought an 02' 996 Turbo. I've had the check engine light come on twice while driving at speed. The car experienced no issues while the light was on and the light eventually went off on its own.
The Durmetric shows the P1109 code. I've read about this quite a bit on here and it seems the obvious things are:
- Heavily soiled throttle
- Throttle adjusting unit faulty
- Mass air flow sensor faulty
I collected some data from the car to see if there are any issues.
MAF voltage reads about 1.04 when the car is off. The Durametric calls this Hot film MAF. When running and going through the entire RPM range this values does not exceed 5 and seems to rise and fall as expected when accelerating or decelerating. From reading on the forum this seems normal.
At 60 mph the reading holds around 2.3.
Car at idle reads about 1.8.
Anything else I can look at with the Durametric to see what may be wrong. For all practical purposes the car runs great.
There's also one other code: 9110 DME control unit, which is related to the instrument cluster. What's this associated with.
Thanks.
Old Jun 2, 2012 | 03:53 AM
Fasoole's Avatar
Fasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant future
I had same problem yestrrday when drive over 120mph i get that light engine and when i slow down it went off
But if i drive more than 120 mph i feel car like dead and cant go more
Took it to the dealer today and im waiting what they are going to ssy
Old Jun 2, 2012 | 08:36 AM
MBailey's Avatar
Thanks.
I would also add boost leak to your list. When I get p1109 its always a boost leak.
Jul 29, 2019 11:13 AM
EMC2
Cayenne 955/957
Sep 7, 2015 05:20 PM
oddjob142
Aug 24, 2015 05:49 PM
silver86
Cayenne 958
Aug 21, 2015 03:08 PM
Aug 19, 2015 06:55 PM
