Boost gage on 996 2001 Turbo?
but would I have a potential clutch problem if I get boost adjusted up to 1.0 bar. Also, do you know if boost has manual adjustment?
EPL tuned my car with 91 octane with 0.9 max boost (due to the lousy gas available here in CA). Usually the tune is set at 1.0 bar. I am easy on the clutch, no hard launches, etc.
Best to check with your tuner about adjustable boost.
If other conditions permit it the DME will allow more boost to compensate.
Simple as that.
I'm really a big fan of turbo-charged engines in the mountains. I got a real nice surprise with my lowly VW Golf TDi with its 1.9l diesel engine. Based on my experiences with large V8 powered USA cars under similar conditions I expected to have to get out and push the Golf over the higher passes but the thing cruised at over 110mph at over 6000 feet above sea level with no problems at all. At other times, even at the highest passes on I-70 west of Denver, I didn't feel the car lost an ounce of get up and go. For comparison when I went through there in my '96 Mustang GT (4.6l, 200+hp, and I forget how much torque) the thing felt pathetic. Andhow the VW Golf and its 1.9l turbo-charged engine was amazing. While driving I viewed the boost pressure though -- connected an OBD2 code reader/data viewer to the car's OBD2 port -- and found it making higher boost at lower rpms than it was making at sea level.
Be careful. These things gather speed at an incredible pace and even at 8K feet my Turbo accelerated like there was no tomorrow. In fact it was kind of cammy as the engine was a bit flat until boost kicked in and then as the boost climbed it felt to me the engine had all its sea level beans back and then some.
Sincerely,
Macster.
Turbo diesels are great for mountains. When it comes time to replace our SUV, we'll be getting a Touareg TDI. Great mileage and a boatload of torque.
The DME attempts to satisfy the torque demanded by the driver. At higher elevations there is less air pressure and the cylinders are filled less effectively. This reduces the amount of torque available at a given throttle opening.
Simple as that.
Sincerely,
Macster.
Simple as that.
Sincerely,
Macster.
I'm pretty sure the dash only reads to 1.5
Anything above that and you will have to reference the boost controller. It will store the peak boost and can be reset.
996TT in my shop now reads 1.6 on the cluster. Alpha 28 car.
Apologies if I'm stating the obvious to the original poster, but to clarify the question on how easy it is to adjust the boost, the answer is that it is very easy, BUT, you have to buy the revised engine software from a tuner and re-flash your computer.
The ECU flashing process itself is very easy and is generally done with either a standalone tool or a cable connected to a PC. You just push some buttons and watch lights blink.
It is not a simple matter of turning a screw or a ****. Tuners generally adjust the air/fuel mixture, boost, and what not throughout the power bad.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
Just Cruise
Aug 25, 2015 10:45 AM
