A30/76 pumpgas
Old Jun 18, 2012 | 10:02 AM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
A30/76 pumpgas
Hello,
I just want to know if anyone is running A30/76 on 1.4bar on pump 93 octane(98 europe) without water/meth.
Old Jun 18, 2012 | 02:09 PM
ek9max's Avatar
ek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud of
I'm running 1.3bar on 91 octane. We had to bump the timing down quite a bit though.
Meth getting installed as we speak
Old Jun 18, 2012 | 02:16 PM
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
yes 1.35-1.4 bar on pump but 94-95 octane (100 oct european), timing ok
Old Jun 18, 2012 | 02:21 PM
Fadi's Avatar
and I own both a tuned 996 and a tuned 335i and I am half Lebanese
Old Jun 18, 2012 | 07:09 PM
Old Jun 18, 2012 | 08:33 PM
Tim941NYC's Avatar
I was running gt3076 with a T3 hot side 20psi boost 93 oct 720 rwhp no meth
Old Jun 18, 2012 | 08:42 PM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Stock bottom end? What injectors?
Old Jun 18, 2012 | 09:31 PM
By the way ,my actual mods are:fender intake,big Y pipe(proto),Mafless proto tune,72lb injectors,serial Bosch 044 fuelpump,switzer monster IC and switzer decated exhaust.
Old Jun 18, 2012 | 10:09 PM
Originally Posted by dynamic gt2
Hello,
sure you can but the timing will be very low... you can achieve the same results at 1.2 bar... or less...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 19, 2012 | 05:40 AM
Tim941NYC's Avatar
Built bottom end of course. 72lbs injector modded to flow 880cc.
Old Jun 19, 2012 | 05:51 AM
Tim941NYC's Avatar
your intake air temps are the biggest factor on how much boost you can run and still make power. Switzer intercoolers are very nice pieces but no air to air intercooler can get your temps below ambient air temp.
Old Jun 19, 2012 | 05:52 AM
k-ore's Avatar
Stock single fuel pump at the time?
Old Jun 19, 2012 | 08:59 AM
How do you mod a 72lb injector to flow more?
Old Jun 19, 2012 | 09:02 AM
Maybe a water/meth injection can solve this issue
Old Jun 19, 2012 | 09:30 AM
BUTZI996TT's Avatar
BUTZI996TT is a jewel in the roughBUTZI996TT is a jewel in the roughBUTZI996TT is a jewel in the rough
Watermeth will definitely help, it is worth the $ at that power level... The peace of mind is def worth it.
