Average cost to replace clutch?
Old Jun 21, 2012 | 05:57 AM
Speedtrapped's Avatar
Speedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant futureSpeedtrapped has a brilliant future
I am sitting a stage 3 CM waiting for the spec stage 3 to fail I guess. I was having issue with slipping in 5th gear, due to the greddy set for 1.47 bar. The tune is set up for 1.2 on protosport 650 package. I was told by one mechanic my clutch is going and bye another there is still life. Ever since readjusting the greddy to 1.2bar, clutch is holding up.
So I'm technically not in a rush to swap it.
I'm just curious what you all have paid to have a clutch swapped out? I have read here and elsewhere, the engine doesn't need to be dropped.
Ty
Stephen
Old Jun 21, 2012 | 09:56 AM
MBailey's Avatar
Labor typically runs about 12-15 hours. Then you have the cost of the clutch.
Old Jun 21, 2012 | 10:08 AM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
well since dealers charge 500$ for a oil change this might give you an idea.
Old Jun 21, 2012 | 10:12 AM
XLR82XS's Avatar
I charge $1350 labor plus parts at my facility.
Old Jun 21, 2012 | 10:16 AM
Ajs76's Avatar
Ajs76 is infamous around these parts
A good indie here charges about 1800 in labor for it. The dealer wants 2800 in labor.
Old Jun 21, 2012 | 10:21 AM
PM me when you actually need to get your clutch swapped. I'll point you the right way. It will be done in a day and at a reasonable cost.
#TeamAIM
Old Jun 21, 2012 | 10:31 AM
johnspeed's Avatar
HI,Our independent shops charge $900 to $1200..The porsche/import shops charge $1200 to $1800....The dealers want around $2500 to $2800..
Good Luck..
Old Jun 21, 2012 | 10:43 AM
Ty all, figured it was going to be above $1k, especially in tri state area. Pm sent
Old Jun 21, 2012 | 11:32 AM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Mark...pm me the info, please!
Old Jun 21, 2012 | 03:00 PM
triblk6spd's Avatar
triblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond repute
Quick addition to the original question....does replacing the release bearing involve an entire "clutch job?" Thanks! Specifically...does it basically require the most of the 14hr time to do a full clutch job or can the release bearing be snuck out w/o dropping the trans and motor and whatnot?
Old Jun 21, 2012 | 03:12 PM
OhioC5's Avatar
OhioC5 is a splendid one to beholdOhioC5 is a splendid one to beholdOhioC5 is a splendid one to beholdOhioC5 is a splendid one to beholdOhioC5 is a splendid one to beholdOhioC5 is a splendid one to beholdOhioC5 is a splendid one to beholdOhioC5 is a splendid one to behold
My friend just paid $600.00 labor. The guy at the shop said there's no need to pull the engine. He will be doing mine as soon as it goes.
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
$2k around these parts (independent shop).
Old Jun 21, 2012 | 06:30 PM
OhioC5's Avatar
I guess some things aren't so bad in Ohio.
Old Jun 22, 2012 | 07:51 AM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
Great pricing in this thread- this has been the main reason I haven't upgraded turbos.
Old Jun 22, 2012 | 08:50 AM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Same here - and I've got new turbos sat in my garage
Think I'm gonna do everything in one swoop once funds allow
