Looking Back - Do You Think You Should Have Stuck With K24/18g?
Old Jun 25, 2012 | 02:38 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Talking Looking Back - Do You Think You Should Have Stuck With K24/18g?
For all you guys running the big kits, what are your thoughts when looking back?
Was the jump-up all you wanted it to be, or could you have survived with a good K24/18 set-up?
Old Jun 25, 2012 | 02:53 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
I was on 24/18's for 1 week. The big kit is a whole lotta fun now!
Old Jun 25, 2012 | 02:59 PM
johnspeed's Avatar
HI, Did you have alot of supporting mods with that set up?
Old Jun 25, 2012 | 03:46 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
The billet 24/20's have a lot more kick.
Old Jun 25, 2012 | 04:02 PM
Yea, I had all of them from dual fuel pumps to intercooler piping.
Old Jun 25, 2012 | 08:13 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Pauli do the billet 24/20's spool faster then the K 24718´s ???
Old Jun 25, 2012 | 08:58 PM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
What whp did you mkae on bille 24/20's? Who makes them? Is it worth going from 18G's to billet 20's? Is it cost effective?
Old Jun 25, 2012 | 09:34 PM
johnspeed's Avatar
I really thought I would go to the 20s after all my supporting mods with the 18s,see my signature.
BUT I was told by a few builders/tuners that at pump gas (93) level it was not worth it?..I might pick up alittle on the top but loose it on the low/low midrange and it would be a bit slower spooling...
Old Jun 25, 2012 | 09:46 PM
johnspeed's Avatar
YES,,,BUT On how much boost, using what fuel??
Where and what do you give up for it if you run only pump gas??
I have spent lots of time researching and talking to others BUT maybe I missed something,always learning....
Old Jun 25, 2012 | 10:46 PM
Turbo Fanatic's Avatar
While the K24/18g is the past of least cost and a great option, it's proven not to have the response or high end power of A28s. Given the fact that these mods require a flash, IC, 5 bar (better yet injectors) and exhaust I think the cost of A28s are well justified.
Old Jun 25, 2012 | 11:45 PM
johnspeed's Avatar
I think others have the same thoughts as you..
Having those mods and spending that money on the A28s,,Wouldnt it be better to go straight to 3071s because they work with those mods, similar cost for turbos and more power every where except at the very low end??
Old Jun 26, 2012 | 04:34 AM
John I have heard the same info about 20's vs 18's on pump gas. The advantage 20's have over the 18's is only above 1.4 bar.
So if you only run pump gas the 20's might not make much sense.
Old Jun 26, 2012 | 12:48 PM
ant_8u's Avatar
Keep out of my thread you - You're trouble
Old Jun 26, 2012 | 01:47 PM
to run a 18g you don't need much.. and its fun... to run anything bigger then that your into thousands of dollars of upgrades... with that said, I do not think its as easy to compare as it sounds... if money is no option then its a different story... do a $30K build and your ready to rock n roll..
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 26, 2012 | 07:30 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
I just did a 24/20 Billet install, the car made 605awhp on 100 octane, 72lb injectors, EVO 3.5" IC's, inlet pipes, remus exhaust 100 cell cats.
Hey, I can see why guys go to the big boy kits for gobs of power and fun... the car handles the 24/20G turbos as if it came from the factory. Totally in control, doesn't feel much different, just pulls like a bastard when your in boost.
