First gear,when do you switch?
Old Jun 28, 2012 | 06:03 AM
BT ZR1's Avatar
BT ZR1 is infamous around these parts
Hi, i have not had my 03 x50 very long. When switching to second, Do you take the rpm's up to 5 or or do you switch earlier? Does taking the rpm up to 6 before switching to second,cause issues with the car's components.?
Old Jun 28, 2012 | 07:41 AM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Racing or DD?
Old Jun 28, 2012 | 09:50 AM
'02996ttx50's Avatar
3-3.5k rpm. unless i'm trying to wake my neighbors.
Old Jun 28, 2012 | 09:55 AM
Ajs76's Avatar
Ajs76 is infamous around these parts
+1 assuming you mean everyday driving. I found this car (maybe just my car) doesn't like being short shifted.
If you're getting on it, I shift around 6k to make sure I don't hit the rev limiter because it happens so quickly.
I assume you aren't revving to 5k in normal street driving. If you are, then you are way more hardcore than me.
Slider's Avatar
It totally depends on the conditions... if you are working your way up to 50 kph (30 mph) on a busy city street, then easy does it. If you are trying to rip the clothes off your girlfriend on an on-ramp, 6.5 K RPM is good.
Old Jun 28, 2012 | 11:45 AM
3-3.5k in *normal* street driving seems optimal to me. it's funny, as i read this thread then went to the store real quick to see, and yeah, 5k in 1st is a bit too on the pipe for regular around town driving. getting on it, is of course another story. 1st is a gear i just want out of asap, so 3.5 k max is good ( for me ).
Old Jun 28, 2012 | 04:13 PM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
3000 -4000 feels right most of the time. And not stabbing the pedal to get to those numbers either, unless of course, it calls for it. First gear is used up so fast anyway, that second is itching for a wind up.
Old Jun 28, 2012 | 04:26 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Casual driving 3-4k. From the dig, you'll hit the rev limiter in nanoseconds so shiift a bit short of redline.
Old Jun 28, 2012 | 06:26 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
Until the engine is warmed up (coolant gauge up on 180 degrees) no more than 3 K revs in ANY gear. When engine is hot, 3-4 K revs in any gear as the power band / torque of the turbo can deal with anything you throw at it in a daily driving situation.
Old Jun 28, 2012 | 06:37 PM
Aerodude's Avatar
Aerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant future
I usually get out of 1st as soon as possible (probably under 4K). First gear is really just there to get the car moving. 2nd gear seems to give me the real acceleration to push me back in my seat and get going .
Old Jun 28, 2012 | 06:55 PM
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
Same here although it doesn't feel like the car is ready to get out of 1st gear at that rpm LOL
Old Jun 29, 2012 | 09:50 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
i added a shift light they are great keeps you from hitting the rev limiter
Old Jun 29, 2012 | 10:49 PM
ard's Avatar
ard
"switch"?
I shift.
Old Jun 29, 2012 | 11:22 PM
Turbo Fanatic's Avatar
Even stock TTs rev so fast in 1st that you will outrun the tach. Shift at like 5900 when gunning it to prevent hitting the limiter at 6700. The tach will look like it's hitting the rev limiter about 500rpms low in first. Again that's just the engine outrunning the tach.
I have a very easy driving style when not going fast. Keep revs above 2300 and you'll be fine in most cruising situations except when climbing a hill.
996GT3TC
Nov 22, 2015 10:43 AM
jaehoppa
Oct 22, 2015 09:17 PM
ELMEL
Sep 28, 2015 01:12 PM
GSP
Sep 9, 2015 05:31 AM
