Put bigger turbos on...car makes less power
Old Jul 17, 2012 | 10:10 PM
  #61
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
tcu is the newest version, but not flashed
my mechanic does not see any codes/faults go on during the runs
my mechanic also says he hears a ticking noise
the car has all new exhaust and intake lifters, valves and stems...perhaps the machine shop that did the work on the valve job messed up
how do you check the exhaust cam without taking out the motor?
Old Jul 18, 2012 | 12:07 AM
  #62
Dr_jitsu's Avatar
Originally Posted by PAULIEWALNUTS
That wouldn't be BHT by any chance.
As we get older, we become more forgetful. However the turbo confusion will never be forgotten.
Old Jul 18, 2012 | 07:48 AM
  #63
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
A little lowblow, I know. What interesting was you were breaking the Tip records left and right with those.
Originally Posted by BlackHorseTurbo
Oh, sofa king funny!
Old Jul 18, 2012 | 08:03 AM
  #64
Tim941NYC's Avatar
Ben,
Intake cam check on the durimetric. exhaust cam, put the motor on tdc bank one and pull the green plug that cover the rear of the cam look at the slot that is used to set the cam and see where it is and compare this to the tool. Bank two you may need to move the oil tank. Do Not rely on the crank pulley notch. use a indicator in plug one.
Old Jul 18, 2012 | 09:00 AM
  #65
bad107's Avatar
they r borrowing tools from nearby p-car dealership
i think they r just pulling motor , but i txted him your instructions
Old Jul 18, 2012 | 01:44 PM
  #66
Tim941NYC's Avatar
Old Jul 18, 2012 | 02:02 PM
  #67
In action....
#TeamAIM
Old Jul 18, 2012 | 07:23 PM
  #68
Tim941NYC's Avatar
LOL.. Mark that was the tare down.. I always check the timing before just to see. Its never been prefect. Or evenly off do to chain ware. water line fitting not fixed and exhaust cam plate not in because of being out of time, intake is in time.
Old Jul 18, 2012 | 08:53 PM
  #69
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
Maybe you need.....BIGGER.....turbos!!
Old Jul 19, 2012 | 11:32 AM
  #70
996ttrbo's Avatar
996ttrbo is infamous around these parts
Bad 107 : is the TCU 996.618.180.04 still available for sale?
Old Jul 19, 2012 | 12:48 PM
  #71
bad107's Avatar
exhaust and intake timing were good
the problem is in the pics below...oil coming from cylinders 3&4
there appears to be oil in the exhaust port and oil around the valve heads
Old Jul 19, 2012 | 12:52 PM
  #72
unvmy996's Avatar
damn that sucks, was your motor built ? is it stock ?
Old Jul 19, 2012 | 12:58 PM
  #73
bad107's Avatar
i am not sure if this shows what is causing the power loss, but i think it shows what is causing the smoking
i just don't understand how my leakdown and compression were good if two cylinders are messed up?
Old Jul 19, 2012 | 01:11 PM
  #74
bad107's Avatar
recently build 3.8 engine...my builder is out of state and does not get along with my mechanic...this is not fun
Old Jul 19, 2012 | 01:37 PM
  #75
Tim941NYC's Avatar
Ben,
Leak down is done on bottom dead center. If there is sleeve damage anywhere above that spot it will not show on a leak down. Bad news is you need to pull off that head and remove the jug and see with your eyes whats going on.
Edit Top dead center..
