Help me Identify this exhaust
Old Jul 20, 2012 | 09:07 PM
rangerdick's Avatar
rangerdick has a spectacular aura aboutrangerdick has a spectacular aura aboutrangerdick has a spectacular aura about
Hi All, This exhaust came off my 2003 996tt. Louder then stock with a slight drone at 2300 rpm cruise. There are no markings or labels. I have searched various manufactures and can't find an exact match. The closest I came to was an MTM exhaust:
http://www.mtm-us.com/en/Porsche/996...=m-p96aga36bqs
The main can has two longitudinal TIG welded seams. The seams have a slight split in the middle, and I need to re-weld them. It appears to be all stainless. The Cat's are pretty big and I've attached a pic of the insides as well.
Any Ideas?
Old Jul 21, 2012 | 11:01 AM
SamboTT@ByDesign's Avatar
Looks like an FVD with 100 CEL cats.
Best,
Sam
Old Jul 21, 2012 | 11:37 AM
johnspeed's Avatar
Best,
Sam
..I think you are right..
Old Jul 21, 2012 | 05:08 PM
targa72e's Avatar
targa72e is infamous around these parts
I would say older MTM with 100 cell cats . Looks just like the one I have in my garage. I
john
Old Jul 21, 2012 | 06:02 PM
rangerdick's Avatar
That probably begs the question, "Why is it in your garage?" But I won't ask. John, Do you have any pics of yours for comparison. I'm debating if I should invest the time into repairing it. It looks like a decent exhaust and the MIG welds on the pipes are beautiful, but I don't have any information on it other then the really bad website. Thanks a bunch.
Old Jul 22, 2012 | 08:57 AM
johnspeed's Avatar
FVD..Go to their website....
Old Jul 22, 2012 | 09:32 AM
bng4god's Avatar
bng4god has a spectacular aura aboutbng4god has a spectacular aura about
You guys also helped to solve my mystery as well! I had the same question last year... see my post link below. Looks like I have different tips but it's the same funky design where the outlet pipes from the muffler are different on either side with a flex pipe on one side. By the way, fitment on this exhaust was horrible! Since then I gutted the entire muffler portion and did a custom x-pipe from the cats back...
https://www.6speedonline.com/forums/...ml#post3267492
Old Jul 22, 2012 | 09:40 AM
bng4god's Avatar
It looks like they don't carry that specific muffler model anymore. Everything is now modular pieces. I bet the reason was probably because of fitment issues with their older system.
I was surprised how bad they fit and my initial hope was to just modify the tips but it was nearly impossible so I just removed the entire muffler portion.
Questions for those that had the older one piece version: How was your fitment? Any issues? Just curious? I don't have it anymore but it's always nice to close the book on a mystery.
Old Jul 22, 2012 | 10:57 AM
targa72e's Avatar
Here are some pics. I just finished building my own 3" x-pipe exhaust thus the exhaust sitting in the garage. The MTM exhausts were quite expensive and used good HJS 100 cell cats. Like most exhausts of this design it has some drone around 2800 rpm. I am not sure what I am going to do with it. Probably sell it or use it to make another X-pipe exhaust.
john
Old Jul 22, 2012 | 03:10 PM
rangerdick's Avatar
Thank you all for the help. The FVD's are very similar and nearly and exact match. The two areas where I saw differences were the "modular design" with no "flex pipe" and the reinforcing stamping on the muffler can. When John (Targa72e) posted the pics of his MTM, that is the exact same one I have. Single Flex pipe and welded can. I think the newer ones have double flex pipes, which probably help with fitment. John, do you remember where your's came from?
I can't say how hard it is to put on, since I only removed it, but it seemed to fit ok. One of the areas I had a problem with was at the taper of the cats to the turbo flange, as the cone into the cats is too steep and interfered with the studs on the turbo, requiring a crow's foot wrench to loosen. I think I will weld it up and save it. I have the stock one back on the tt now and it' great for daily driver. When I have my second mid-life crisis and fully mod the car, the MTM goes back on. Again, thanks to all
Old Jul 22, 2012 | 03:18 PM
rangerdick's Avatar
BNG4God, the tips are Porsche OE. Eisemen or Boysen. They are interchangeable and were options when ordering originally. 4 hole or 2 hole. Make sure you use penetrating oil if you ever try and loosen the clamps. Can be a bugger to get off. And use Anti-Seize when putting new ones on.
gulf gt
Aug 27, 2015 10:27 AM
Zero911
Aug 24, 2015 06:51 PM
Ferrari
Aug 24, 2015 04:35 PM
PenguiN
Aug 21, 2015 10:11 AM
