Are the Ruf springs all I need
Old Jun 12, 2005 | 08:07 PM
Doug H's Avatar
Doug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud of
to lower my car 25 mm. I have a stock 04 TT cabriolet that feels like a 4X4 compared to my coupe with H&R on it.
Ruf auto center has a set of spring that says will lower 25 mm when mounted on factory dampers.
Excuse my ignorance, but does this mean I can install these springs and lower my ride height for only $ 549.00.
The springs can be found here.
http://www.rufautocenter.com/parts/pdf/996.pdf
Old Jun 12, 2005 | 09:35 PM
01-996's Avatar
01-996 is infamous around these parts
Yes that is true.....But, the main cost in upgarding suspension is the labor. So if you got to install for 1200+600 for the part, why not pay 1200 for the coilovers and 1200 for the labor, since u are already in there...
Old Jun 12, 2005 | 10:28 PM
JNRSM3's Avatar
JNRSM3 is a name known to allJNRSM3 is a name known to allJNRSM3 is a name known to allJNRSM3 is a name known to allJNRSM3 is a name known to allJNRSM3 is a name known to all
1200 for install? Wow, that's a bit high, I believe.
Old Jun 12, 2005 | 10:46 PM
ZAMIRZ's Avatar
ZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud of
It should cost less labor-wise to install a full aftermarket spring/strut assembly in place of the stock setup.
Doug, how have you been? I haven't seen you around on the forums lately, hope all is well with the cars. I see there's been at least one addition, the cab, recently.
Old Jun 13, 2005 | 11:35 AM
Doug H's Avatar
Hey Amir. Been busy and kind of out of cars for about year. I have this new 2004 TT cabriolet needing mods so I am back for help from the experts.
I did trade my TT coupe in on a TT cabriolet. I miss my TT coupe as it was perfect as far as interior and mods. Nice to have a TT drop top thought to drive every day.
I also added a Ferrari 355 spider to the mix. I really like the 355 for the wow factor as far as looks, but the car is basically crap compared to the 996 TT mechanically. Hard to explain. Love the engine and sound, but it seems so fragile compared to my Porsches.
Have not had it long and feel like every time I drive it something is going to break. I picked it up dirt cheap and now thinking about trading it for a Lamborghini Diablo 6.0 maybe.
Old Jun 13, 2005 | 12:23 PM
Orli930's Avatar
Orli930 is infamous around these parts
I would just go for the coil over and skip the springs.
Soon or later you will upgrading anyway, so just spend the money now.
Old Jun 13, 2005 | 12:25 PM
Ruiner's Avatar
It's about $1000-1100 here in Atlanta. The $1100 that I quoted includes corner balancing and alignment as well.
Old Jun 13, 2005 | 02:18 PM
Red Comet's Avatar
Red Comet is infamous around these parts
I'm surprised Ruf sells a springs-only suspension kit. In my experience, lowering springs make a 996 Turbo harsh and downright scary to drive fast. You should seriously consider coilovers.
Old Jun 13, 2005 | 02:41 PM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
I have Techart Springs
car handles absolutely fab at all speeds but the install costs are correct I was kinda shocked too but its still worth it.
Old Jun 13, 2005 | 02:47 PM
Super D's Avatar
You're SO MONEY, baby!
Super D Is a GOD !Super D Is a GOD !Super D Is a GOD !Super D Is a GOD !Super D Is a GOD !Super D Is a GOD !Super D Is a GOD !Super D Is a GOD !Super D Is a GOD !Super D Is a GOD !Super D Is a GOD !
If you've got stock dampers that are made to work with stock springs, but just switch to firmer lowering springs--you'll be matching up a higher spring rate lowering spring and losing travel and optimal damper performance from the OE damper. Just my opinion, but I agree with others here--go for a matched coil-over set that was designed to work as a matching combo. You could even offset the cost of buying the new dampers by selling the old ones and recouping a few hundy.
Old Jun 13, 2005 | 09:18 PM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
Thumbs down springs only?
My car had only lowered springs when I got it and I was riding on the bump stops. This is very unstable in bumps at high speed. Now have PSS9 and there is no comparison. Save money by the correct amount now. Porches arent cheap. Making them better isn't either.
Silver
silversrt
Jan 24, 2016 03:45 PM
DannyK
Ferrari
Nov 27, 2015 05:56 PM
4080
Oct 5, 2015 01:44 PM
Ronny-
Oct 1, 2015 10:40 AM
PelicanParts.com
Sep 25, 2015 03:17 PM
