Engine died and now refuses to start, idea??
Old Aug 9, 2012 | 06:44 PM
Darth GF's Avatar
Darth GF is infamous around these parts
I was getting on the highway, I gunned the throttle coming on the on-ramp. Then no power. engine still turned but pressing the throttle wouldn't change a thing.
I pulled on the shoulder safely. Turned it off. Then tried to start it. Engine will turn but won't start. The electric stuff works and I have fuel. So it's not the battery or alt or lack of fuel.
Looked under the car. No leaks of any kind.
So far, thinking about it I came to a few probable causes:
1- Fuel pump
2- Fuse
3- Security system went haywire
Any ideas? Car has 45,000km.
Old Aug 9, 2012 | 06:55 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
It's a 2003 Turbo. Correct?? Any maintenance / repair done lately where parts were replaced ?? Best is to get the ECU codes pulled first. You will be chasing your tail if problem is not obvious. Keep us posted and good luck
Old Aug 9, 2012 | 07:57 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
I vote for #1 but going to say something with the line from the pump
Old Aug 9, 2012 | 08:47 PM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Is it stock or modified at all? Starting comes down to fuel, air, and spark. Air is rarely the problem (though a bad MAF can do this), so that leaves spark and fuel. Do you hear the fuel pump cycle briefly when you turn the car off and then put the key back in and turn it on? If not, then I'd start there. Something with the ECU can certainly cause a problem, but that's usually only on a modified car.
Old Aug 9, 2012 | 08:59 PM
Darth GF's Avatar
Car is a 996tt X50 with UMW. Everything else is stock. I doubt the ECU is the problem.
I don't have any code. That's kinda weird. And the reason why I thought of fuse first. I couldn't hear the pump but I was stuck on the side of the highway so I couldn't hear myself think.
Will have a look at it tomorrow and will let you all know.
Old Aug 9, 2012 | 11:09 PM
richgraham's Avatar
richgraham is a jewel in the roughrichgraham is a jewel in the roughrichgraham is a jewel in the rough
my fuel pump did that to me. it's a complex beast pulling fuel from 3 lobes simultaneously. lose suction somewhere in one of the lines and it's all over.
Old Aug 9, 2012 | 11:22 PM
calfrank's Avatar
calfrank is infamous around these parts
Sounds like fuel pump to me.
Old Aug 10, 2012 | 12:06 AM
machinegunt's Avatar
machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !
I concur on the fuel pump! Good luck.
Old Aug 10, 2012 | 08:29 AM
landjet's Avatar
Fuel pump relay is cheap. I'd try that before the fuel pump.
Old Aug 10, 2012 | 11:52 AM
wross996TT's Avatar
What happened to me (twice) is the fuel line ruptured in the fuel tank. The pump just pumed the fuel back into the tank. It was fixed under warranty twice.
Old Aug 10, 2012 | 03:15 PM
LiNks's Avatar
Originally Posted by wross996tt
what happened to me (twice) is the fuel line ruptured in the fuel tank. The pump just pumed the fuel back into the tank. It was fixed under warranty twice.
+1...
Old Aug 10, 2012 | 06:59 PM
Tim941NYC's Avatar
I am with LiNks and wross996tt on this one..
Old Aug 10, 2012 | 08:55 PM
Originally Posted by LiNks
+1...
+2 That happened to my car as well when the previous owner had it!
Old Aug 11, 2012 | 01:14 PM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Ruptured fuel line......very very common
However a small split will usually give enough fuel pressure for the car to cough and splutter even if it doesn't run.
fuel pump failure or pump relay failure and then you wont even get a splutter.
As already said listen for the pump you can bypass the relay and make the pump run continuously if you want to disprove relay defect.
If you had a durametric you could run the pump form the laptop.
If you know anyone with a fuel pressure gauge you could check the pressure at the filter and with a Jar and check the flow.
The fuel pump may be complex ed with pick up's but it isn't hard to remove it and bench test. The U pipe that splits is easily identifiable as just that a U pipe about 2to3 inches long with a very tight radius....which is where the problems lies after many years.
Old Aug 11, 2012 | 01:29 PM
Pizzamangtr's Avatar
Pizzamangtr is a splendid one to beholdPizzamangtr is a splendid one to beholdPizzamangtr is a splendid one to beholdPizzamangtr is a splendid one to beholdPizzamangtr is a splendid one to beholdPizzamangtr is a splendid one to beholdPizzamangtr is a splendid one to behold
What about intercooler pipe blowing off? Any factory turbo charged car I had that popped a ic pipe off did the same thing.
