plenum
Old Aug 21, 2012 | 09:16 PM
  #61
Prche951's Avatar
Tim, it's interesting that the design even on turbo cars is still such that it allows straight pulses across. The picture was part of another post and it was meant to show how all the F6's turbo or not come with it. As of yet, there is no independent test showing an improvement and many knowledgeable people who say it does not show any improvement aside from seat of the pants. And others have felt a loss. If you have independent proof otherwise, cool. But all I have heard about is seat of the pants feel and that is all.
I know a few who build these engines that will disagree with you. So until people show proof there is none to show improvement.
Old Aug 21, 2012 | 09:42 PM
  #62
Prche951's Avatar
John, in that thread of yours, after you fixed the leak, you indicated better feel and performance and after looking at your dyno, it does look to me like the IPD did indeed give you a slight gain at the top end. Maybe not the dramatic gain as expected, but after you replaced everything you did have a leak and this could have accounted for the loss. I also now remember BBI having done dyno with more impressive results on this plenum.
Old Aug 21, 2012 | 10:16 PM
  #63
johnspeed's Avatar
Hi, Others also say the same thing about a leak??I did state these below facts in my thread and I guess other people miss that part too??
I said when I got home from the dealer'AFTER'the dyno test the idle went to a steady 1200rpm..
I also said it was a hot day and I took the highway home from the dealer and just ran it hard on Highway,probably when the hose came off,so I couldnt tell how it was in the other ranges.
It did idle perfect, 750 rpm after the install and on the dyno..I made sure everything checked out before the dyno pulls..I would never do a test if something was not right...One of the those 3 front left had side hoses popped off...I know it was put on during the install ..
Also remember the switch from a 68 mm to 74 mm TB in this..
Old Aug 22, 2012 | 05:15 AM
  #64
Prche951's Avatar
Ok, but even you noticed more responsiveness and your dyno shows an improvement ever so slight. I may include this in my dyno tests to come
Old Aug 22, 2012 | 06:09 AM
  #65
Tim941NYC's Avatar
Not really.. the N/A motors have large cross overs with a valve. the turbo motor only crosses through the plenum.
Old Aug 22, 2012 | 07:28 AM
  #66
Prche951's Avatar
There seems to be two sides to this story and there seems to be some proof on both as well. I don't think anyone in here sets out to prove that it doesn't work. However, one common denominator that all have stated is that there is definitely more responsiveness and feels like more power. So there has to be some improvement however so slight. I looked up BBI's thread and I fully believe they saw results. Also looking closer at the plenum, if it is like the one pictured, there is a line of sight from one side to the other.
I am going to be hitting the drag strip and the dyno, so I may get one and compare before and after.
Old Aug 23, 2012 | 11:52 AM
  #67
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
The dimples actually create lift which in turn give longer distances, if the Cd is decreased, it would be minimal on that shape object.
Originally Posted by Engine Guy
Hmm I could go into a more technical explaination but lets keep it simple... The rough sand cast surface is just enough to allow the flowing air to not attach or stick to the surface. Air that is attached basically has more drag or friction involment with the surface. The small micro layer of disturbed air that the sand like rough cast surface has allows the main air charge to glide in easier; like a hover craft gliding on its own cushion of air...
Think of a golf ball, it cuts throught the air easier due to its dimples. The priciples are slightly different but the same.
Intake piping especially those with corners benefit from surface roughness too.
Old Aug 23, 2012 | 12:05 PM
  #68
DEEPBLUE's Avatar
Greg, do you have dynos or other comparable data sheets for the claimed 35-40whp/tq gains with just an IPD Plenum? These are indeed impressive numbers.
While intake flow is important (especially on NA cars), the combustion and expulsion efficiency would have the greatest gains, I've seen as much as 20-25hp max from a high quality, port matched headers/exhaust combo on the 996tt. I'd guess you could use that patented Y design in the header collectors and make mad power increases as well.
Btw, for conversation, what is the patent number of your Y design? I am interested in reading how this design is generating that much power.
Originally Posted by IPD Greg
3. Since the IPD Plenum is a product of efficiency it should be the absolute very FIRST mod you install on any late model Porsche, especially the 996 Turbo. The 996 Turbo IPD Plenum develops 35-40 HP and Torque (@ wheels) of noticeable “seat of the pants” power gains on a bone stock 996 Turbos.
4. The patented “Y” design of the IPD Plenum delivers the bulk of the power, not the larger throttle body. As a matter of fact, the 68mm Plenum and 68mm TB deliver about the same 35-40 WHP as the 74mm Plenum and 74mm TB. The only difference is that the 74mm set-up will support the more heavily modded Turbos (all the way up to 1000+ WHP)....
Old Aug 23, 2012 | 05:49 PM
  #69
Prche951's Avatar
Good points and I have heard from others privately that they lost power when the TB was the same size. The plenum that BBI tested had a 74-75mm TB versus the std 68mm TB, I can totally see the reason for the gain in power in the version, since that is a major difference in TB's, but this one listed above uses the stock TB.
Old Aug 23, 2012 | 09:10 PM
  #70
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Dimples or sandpaper will trip a turbulent boundary layer on a relatively smooth surface sooner.
The turbulent boundary layer has more energy and MORE surface drag, but it also keeps the flow outside of the boundary layer attached longer around the curvature on the back side of the golf ball (or whatever changing surface your trying to get flow to bend around).
The pressure drag reduction from delaying flow separation can outweigh the increased skin friction drag from the longer turbulent BL (in the case of the golf ball, it does).
Total drag drops, L/D goes up, ball goes further (or the intake du jour has less pressure loss, etc)
/aero eng rant off/
From what I have seen of many tuners stuff in the P car world is they do not get the principle of boundary layer separation and air flow dynamics.
no comment
Old Aug 23, 2012 | 09:43 PM
  #71
Prche951's Avatar
I am sure that losses in a 5 ft distance will be negligible with rough or smooth pipe. I don't think this is where the argument lies on either side. Do any of you wish to show psi losses for a 15 psi, 5 ft, 2.5-3 inch diameter pipe. You wanna bet that it will be low enough not to matter. The y-design from ipd makes sense to me, but the counter argument about bellows t-type system from people that know these engines better than I do is hard to counter.
Even the new GT2RS uses a T-type plenum instead of a y-plenum. Porsche knows it's stuff and they did not switch to a y, why?
Old Aug 23, 2012 | 10:33 PM
  #72
Tim941NYC's Avatar
/aero eng rant off/
no comment
Earl,
You are quite knowledgeable and apply it correctly. The vacuum test before the turbo... Intercooler testing... Reps to you.
Old Aug 23, 2012 | 10:49 PM
  #73
Tim941NYC's Avatar
I agree with you on the loss on pipe. I do not disagree with your last statement but if the power increases do not warrant the extra cost of manufacturing that design then the Value Engineer will put a stop to it. Like bolts instead of studs or gluing the coolant fittings
Old Aug 24, 2012 | 07:00 AM
  #74
Prche951's Avatar
That last statement has a quantifiable value. We are talking about a limited production car with a sticker of 300k. I think that if there was any way that porsche could make the power delivery better, they would have modified that one simple piece. To date, not one factory flat 6 porsche, neither race nor street has it, not even the 956/962's. Just sayin.
Old Aug 25, 2012 | 09:14 AM
  #75
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
Hello,
The first day i installed the plenum and the 74mmTB,everything was fine but the second day i had an issue:when i start the car the rpm goes to 1000 then drop to 800 after 20 seconds which is normal,but just after running the car 15 to 20min the rpm become 1200 ,i checked all vacuum lines and did pressure test,didnt find any leak,Do you think there is a problem with the new TB?at partial and wot the car is running well.
Thanks.
