Spoiler issue again! Imagine that?
Old Aug 26, 2012 | 09:22 AM
'02996ttx50's Avatar
Originally Posted by Dock (Atlanta)
Define uncommon.
look it up.
Old Aug 26, 2012 | 09:35 AM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Originally Posted by '02996ttx50
look it up.
Don't need to.
How many 996 Turbos were sold and what percentage of them have had spoiler system failures?
Old Aug 26, 2012 | 09:43 AM
Don't need to.
then why did you ask?
enough so that any characterization of a spoiler problem on the 996t as "common" would be considered by most as "reasonable", and would prevent *most* people from arguing the semantics of the characterization.
but i understand you as "different", at least in that regard
Old Aug 26, 2012 | 10:14 AM
Because I am interested in what data you are using to characterize my spoiler experience as "uncommon".
Old Aug 26, 2012 | 10:46 AM
i don't believe you.
Old Aug 26, 2012 | 11:18 AM
Why not?
Do you consider it unreasonable for me to ask for the data you used to reach your conclusion that my spoiler system experience is uncommon?
Old Aug 26, 2012 | 12:33 PM
Why not?
why not? because the reports of spoiler issues/failures ( whatever one decides to call them ) are legion, and not the stuff of myth AND.. i know that you know that. so, do i consider your inference that spoiler problems/failure are NOT common, "unreasonable"? yes, i do. particularly given your many years of participation in these forums. honestly, i think you are being deliberately contentious.
i think you should go for a nice long drive
Old Aug 26, 2012 | 04:23 PM
I'm not at all being contentious. The fact that there have been threads/posts here about spoiler system failures does not mean these failures are common. As a matter of fact, I'd bet that some threads/posts are from the same car but different owner, in affect being rung up "twice" based on only one car, or in some cases it's a repeat problem from the same car/owner based on the real issue never being fixed to begin with (neither being conducive to good statistics). I asked you about percentages because it would represent hard data that could then be used to decide if the word "common" applied. Of course the definition of "common" would have to be agreed upon since some would opine that a 20% failure rate would be considered to be sufficient to rise to the level of "common", while others may believe it would require a 40% failure rate to reach "common". Using the very small sample size of this or another forum (Rennlist), or combining the two forums together in terms of "data collection", to form an opinion relative to the total number of spoiler system failures versus the total number of Turbos sold, would be short sighted.
And of course I have never seen any research that identifies spoiler system failures solely to the mechanics and design of the system and not to something owners may have done to the system that contributed to the failures (like excessive cleaning of the tubes, or applying something to the tubes in an attempt to perform periodic maintenance on them, or pushing down too hard on either side of the wing when detailing the car (wing extended)).
Do spoiler system failures occur? Of course. Are they common? That hasn't been statistically determined.
Old Aug 26, 2012 | 04:44 PM
now i just think you're batsh*t crazy, and will leave it at that. i hope you had a nice drive. i did.
Old Aug 26, 2012 | 05:05 PM
now i just think you're batsh*t crazy...
And I think you can't intellectually support your opinion about spoiler system failures.
Old Aug 26, 2012 | 05:58 PM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
Here's my theory on the wing issue.
The first part of the issue is when the wing is in the down position, the piston seals in the rams are not being lubed as the seals are above the fluid. As the fluid pushes the pistons up to raise the rams, they are lubed with fluid.
The second part of the issue is the wing doesn't raise until 75mph.
Basically if you don't drive the car very often, don't manually raise the wing or rarely driven above 75mph, then the seals dry out and begin to leak.
If this is left unattended, then the wing will raise on one side and not the other causing the pistons in the rams to bind. As the pump continues to try to raise the rams, damage then occurs in the pump itself.
I could easily see the seals in the wings lasting a long time if the wing is cycled up at least a couple of times a week.
Just my 2 cents,
Steve
Old Aug 28, 2012 | 09:54 AM
Empyreal's Avatar
Empyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to behold
Just my 2 cents,
Steve
Thanks, Steve, for justification for driving 75+. Not that I needed one, but it's good to know that as well as having fun, I'm also doing passive preventive maintenance.
COBB Tuning
Jan 1, 2025 09:02 AM
PV=nRT.
Sep 9, 2022 06:06 PM
3WDistributing
31
Oct 27, 2017 01:26 PM
cm09578
Sep 22, 2015 06:07 AM
Fester
Sep 8, 2015 09:35 AM
