anyone heard of or know how to fix
Old Oct 25, 2003 | 07:41 PM
ben, lj's Avatar
Senior Member
ben, lj has a spectacular aura aboutben, lj has a spectacular aura about
a problem with a bone dry 996 (NA or TT) not accepting any gas (ie: spitting it out as fast as you can pour it)?
Old Oct 25, 2003 | 11:26 PM
racer63's Avatar
racer63 is infamous around these parts
Wierd. Can't help you there. Saw your car at EVO yesterday though. The install looks incredible! Really nice. The car also sounds awesome. I think you're going to love it!
-Donn
Old Oct 26, 2003 | 06:56 AM
ESK's Avatar
ESK
Hick from NH
ESK is infamous around these parts
Ben,
It sounds like the vent is blocked. When this happens, it's as if the fuel tank is filled.
Eric
Old Oct 26, 2003 | 07:26 AM
ben, lj's Avatar
Senior Member
thanks
Old Oct 27, 2003 | 09:36 AM
NC Bob's Avatar
NC Bob is infamous around these parts
Re: anyone heard of or know how to fix
Got ya covered, Ben. My TT had the same problem. There are two flaps in the fuel tube leading to the tank. The outer flap (door) controls the one downstream. Stick your finger in the opening and push in the outer door. If you hear a click, that is the inner door being actuated by a solenoid switch. If the inner door does not open, the tank will not accept fuel.
There is an exposed plug under the passenger dash that rubs against metal and shorts out causing the inner door to malfunction. My dealer simply wrapped tape around the exposed plug, replaced the fuse and the problem was solved.
In any event, your problem is because the inner door is not working. My cause was the plug. Your cause may be different. Check the fuses.
Old Oct 27, 2003 | 09:51 AM
ben, lj's Avatar
Senior Member
thanks a bunch. it was the fuse.
Old Oct 27, 2003 | 10:01 AM
NC Bob's Avatar
Now check why the fuse blew
Old Oct 27, 2003 | 10:38 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Does this apply to all 996 models including the GT3??? If so, which fuse is it so that I can be prepared in the event it happens to me in the future. Which fuse bay (name) is it??? Thanks
Old Oct 27, 2003 | 11:17 AM
ben, lj's Avatar
Senior Member
crimped wire. sorry but i don't know which fuse. it also runs the rear spoiler, a/c blower, and heated seats.
Old Oct 27, 2003 | 12:24 PM
ESK's Avatar
ESK
Hick from NH
Ben,
O/T but important. How are you and others from the area doing with the wild fires? I was in La Jolla in June and was wondering how close to you they are?
Eric
Old Oct 27, 2003 | 12:38 PM
ben, lj's Avatar
Senior Member
hey eric. all is well in lj. it's smoky as hell, and ash is everywhere, but little chance of the fires spreading here. thanks for asking.
Old Oct 27, 2003 | 12:46 PM
Gary (Fl)'s Avatar
The Newest "Bling King"
Gary (Fl) is infamous around these parts
Great news... Ben, when do you get your car back?
Old Oct 27, 2003 | 12:55 PM
ben, lj's Avatar
Senior Member
friday or saturday. all the roads were closed into san diego yesterday and all southwest flights were cancelled in and out of here.
SlinginHoss
11
Oct 8, 2025 05:16 PM
freddiemac
Oct 7, 2015 11:05 AM
flewis763
Oct 4, 2015 04:14 PM
drkbrent
Oct 1, 2015 07:30 AM
