car choking?
Old Oct 9, 2012 | 02:21 PM
wross996TT's Avatar
Have you cleaned the TB?
Old Oct 9, 2012 | 02:25 PM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
"Looked" clean the last time .... I suppose will look again ...
Old Oct 9, 2012 | 03:18 PM
03 996tt's Avatar
03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future
Did you recalibrate the TB or just disconnect the battery? If you havent recalibrated yet, try the following:
Disconnect batt for a few minutes. After the battery is connected.
1. Switch the ignition on for 1 minute without starting the engine. Do not actuate
accelerator pedal.
2. Switch off ignition for at least 10 seconds.
This completes the adaptation of the throttle adjusting unit
Old Oct 9, 2012 | 03:30 PM
XR4Tim's Avatar
XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !
How did you check for boost leaks? Any leak between the MAF and the turbos can cause this problem. Faulty diverter valves can also do this.
Old Oct 11, 2012 | 03:06 PM
innisdb's Avatar
innisdb is infamous around these parts
taking my car in tomorrow for oil change and having them take a look while its there, ill update once i figure it out! thanks for all the info guys
Old Oct 15, 2012 | 02:24 PM
Saint Ari's Avatar
accelerator pedal.
Did this earlier ... when I started the car .. the car would stall ... I had to rev it up a few times and it had to relearn ... the rev ran up and down for a little while until it stabilized ...
Not sure if that did anything ... or that means something ....
Old Oct 15, 2012 | 05:25 PM
03 996tt's Avatar
obviously not the throttle body as mine fired right up and was smooth as glass within 1-2 minutes. In fact, my car use to be VERY loud during the warm up process but was much quieter once completed.
Old Oct 15, 2012 | 11:41 PM
Ajs76's Avatar
Ajs76 is infamous around these parts
Do you have a LWFW? My car does this very very infrequently and I read on this forum that it had something to do with that. All armchair quarterbacking though
Old Oct 16, 2012 | 12:36 AM
Saint Ari's Avatar
Bonestock.
Old Oct 23, 2012 | 02:55 AM
metzos's Avatar
metzos is infamous around these parts
I have the same problem...i cant figure the problem as well.....
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
r_matt_6
Oct 8, 2015 06:07 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 21, 2015 09:56 AM
