car choking?
car choking?
I have a problem with my car, If I rev match when downshifting and I'm slowing down to a stop and I push the clutch to take it out of gear, the rpm's will drop to about 500 and then go to normal idle. However sometimes the car will just completely die and shut off. Not sure what the problem could be...anyone else have any issue like this?
I'm in the same boat ... can't figure it out ...
I tried testing for boost leaks - NONE
Split fuel pump line - NONE
Had my Durametric run read - NONE
So I'm kinda annoyed by it ... if anyone can help me ... will name my first born after ya ....
Coils are pretty well luck of the draw. I used to replace them one at a time when they failed - until I bought the BBI coil packs. Now I don't replace them at all. You may have put in new ones, but one of them isn't 100%. It's no easy task finding the one that's causing trouble either. (That's why I paid the big bucks for BBI)
what gap are you running on the plugs?
#TeamAIM
#TeamAIM
Disconnect batt and reset the tb. search for it, it corrected my hunting and stalling problem. Cleaning the maf would be my second recommendation.
How many miles do you have on your car? I would suspect the coil packs though. Hope you get it figured out, I know it's annoying when you can't pinpoint the problem.
+1
MAF changed about a year ago.
No boostleaks
Disconnected the battery a few times
Fuel pump hose not split
still chokes every so often ... I have to blip the throttle when slowing down to a stop so I'm sure not to stall.
