fault codes
Old Oct 17, 2012 | 11:53 AM
996Tripp's Avatar
996Tripp is infamous around these parts
fault codes
on 996TT with evo gt 660.The codes are po 171, po 174, po 507, and po 1109.
Whats going here.I am new here so be kind.what should i do first.
thank you, 996tripp
Old Oct 17, 2012 | 12:01 PM
wross996TT's Avatar
0-36.2 P0171, P0174
Oxygen Sensing Adaptation, Idle Range, Bank 1 & Bank 2 –
Above Limit
Possible fault cause
♦ Incorrect signal from MAF sensor
♦ Intake air system leaking
♦ Fuel pressure too low
♦ Volume supply of fuel pump too low
♦ Fuel injectors fouled
♦ PCV valve leaks
♦ Cap of oil filler neck not closed correctly or seal is damaged
P0507
32 Idle air control at stop - above limit
♦ Throttle is jammed
♦ Leaks in intake air system
I would first check for leaks to the system (check hoses and connections).
Old Oct 17, 2012 | 02:37 PM
996Tripp's Avatar
hey thanks, 996tripp
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
1gr8e39
Oct 1, 2015 04:07 PM
davetherave
Bentley
Sep 11, 2015 04:15 AM
Nuke
Sep 8, 2015 09:09 AM
