What is the newest recommended Coil & Plugs setup?
Old Nov 15, 2012 | 02:47 PM
Slider's Avatar
Originally Posted by '02996ttx50
can you share? idle.. throttle response? and would you replace perfectly good 997 coils for these at 800 a pop? i can see how they might be worth it.
I had new 997 coils and one of them went bad and I ordered the BBI Coils. I replaced the 997 coil and everything seemed great... until I put in the BBI coils and saw how much smoother the response was at every RPM. Very Very noticeable. Guaranteed for as long as you own the car. Well worth it for the money - no more screwing around with coils.
Old Nov 15, 2012 | 04:57 PM
'02996ttx50's Avatar
thanks for the info. i'm not surprised, and wish i had them. but i'm going to wait until if/when one of my 997 coils goes, then i would definitely go for the upgraded bbi's. for now, though i'm hoping my next 800 bucks spent goes toward new led tails lol
Old Nov 15, 2012 | 06:04 PM
johnspeed's Avatar
Just to mention a thought here >> When we change our plugs, most of the time there is noticable feel in performance..So,when we change the coils we also change the plugs at the same time ?
Just curious if any one has changed a perfectly good OEM coil with a 'Better' coil with out changing plugs?? I am talking on an average/mild modified or stock car...
Usually a better coil is going to have more voltage and better recovery time, so you can open up a plug gap then get to bigger/stronger spark thus a better burn..Plus its harder to blow out the spark then also..
But the question is at what level will that help if in fact the coils actually do have more voltage and better recovery time?
Just my thoughts ..
Old Nov 15, 2012 | 07:09 PM
i thought it was some kind of unwritten law to change coils and plugs at the same time. show's ya what i know
Old Nov 15, 2012 | 07:27 PM
johnspeed's Avatar
I still have my original ones ,40,000 miles, and several plug changes.
And my car runs great up to 7400rpm with 1.4 bars.
Old Nov 16, 2012 | 06:25 AM
i must have been thinking back to cars with cheaper parts! x'lnt john! rep #101 for you lol
Old Nov 16, 2012 | 12:39 PM
i use Mercedes Benz coils that look like BBi coils.
#TeamAIM
Old Nov 16, 2012 | 01:29 PM
Tim941NYC's Avatar
I use ford coils and bosch xr4cs plug.. I know they wont work on a stock car..haha. I always had very good luck with bosch F5DP0R plugs.
Old Nov 16, 2012 | 02:25 PM
sales@bisimoto's Avatar
sales@bisimoto is infamous around these parts
Smile
We have had great success with NGK Iridium plugs, part number starting with BKR. The very fine Iridium tip, will ensure a durable and a constant stable spark, with several heat ranges to selected from depending on application to be tuned. Feel free to PM for a options on your project.
Old Nov 16, 2012 | 02:50 PM
MegioN's Avatar
MegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to all
Guys, I have 1220hp now and stock ignition, I am gonna go to 1400+
What coils and plugs should i go? Really all my minds about pro efi ignition...
Share ur minds plz!
Highlander
Jan 3, 2020 03:14 PM
HotRod
Sep 10, 2015 07:17 PM
BauerR
Sep 4, 2015 10:47 AM
oddjob142
Aug 24, 2015 05:49 PM
Highlander
Aug 23, 2015 09:05 PM
