BLACK FRIDAY SALE on Adjustable Rear Control Arms @ USP !!!
20% OFF !!!
USP Motorsports Rear Adjustable Control Arms <--- CLICK HERE TO ORDER!
PLEASE ENTER THIS COUPON CODE AT CHECKOUT: PCABF
Porsche vehicles come from the factory with negative rear camber for maximum performance handling. This is great for track use, but when driving the vehicle regularly it will destroy the inside of the tires very fast. When lowering the Porsche, camber becomes very bad and additional adjustment is a must to maintain normal tire wear. To remedy this problem, USP Motorsports has developed these adjustable control arms for your Porsche 996 and 997 vehicle. These control arms are a direct replacement for your factory rear arms, and assist with adjusting camber and toe. They are a CNC machined 6061 lightweight aluminum construction. In addition to being adjustable, these control arms also offer increased strength from the replacement of the factory urethane bushing with spherical bearing heim joint ends.
These arms are also ideal when setting up a track inspired Porsche with a spring or coilover setup. You will need maximum adjustment to set camber to spec. Each spherical bearing has CNC machined billet steel fittings for a secure and safe fit. Control arms are sold in sets of 4 and fit all 996 and 997 chassis Porsche vehicles. Lifetime warranty to the original purchaser.
20% OFF !!!
- prevent premature tire wear
- light weight and high quality
- perfect replacement fit
- 0-3 degrees camber adjustment
- 6061 CNC machined aluminum (Available in chromoly steel upon request)
- great for lowered 996s & 997s
- Spherical bearing heim joints
- 4 way 19mm hex key for ease of adjustment during alignment in middle of bar
20% OFF !!!
Thank you all for the orders, they are steady coming in this is a great product to get out there on these cars.
Chris Green@USP
997 Turbo Vendor Classifieds
01-28-2016 02:22 PM
COBB Tuning
11-09-2015 08:02 PM
Chris Green@USP
996 Turbo Vendor Classifieds
08-20-2015 11:30 AM
